valve stem oil seals question
Old Jun 6, 2006 | 11:13 AM
sufsRS's Avatar
sufsRS
Default valve stem oil seals question
changed my valve stem oil seals, i have been told teh car will still smoke for a while but for how long?? Also theirs some traces of oil in the exhaust is that turbo gone
Old Jun 6, 2006 | 11:46 AM
Bungle's Avatar
Bungle
Sounds like turbo seals mate unfortunately i've been there and done this when i had my s2, changed the valve stem oil seals like you and still blue smoke,
I then took it to my local tuners and they said there should be no smoke almost straight after starting i then swapped my turbo with my mates while his rs was off road and no smoke with his turbo at all,
Have you got a good mate that could do the same for you to save you buying bits you may not need? hope this helps cheers and good luck, Grant
xrmalin
Sep 13, 2015 06:52 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
Danielbetty
Aug 28, 2015 08:01 PM
st220kyle
16
Aug 14, 2015 06:13 AM
