3dr rev counter problem
Old Aug 9, 2004 | 03:53 PM
B11GNS's Avatar
B11GNS
Default 3dr rev counter problem
my rev counter is working but it reads a lot less than it should do. It was working fine yesterday but turned it on this morning and it now has the problem. Does anyone know what the problem might be?
Old Aug 9, 2004 | 03:59 PM
Matt's Avatar
Matt
check.....
the multiplug in the passenger footwell where the engine/ecu loom plugs to the dash loom
the multiplug behind the clocks....
(green wire 2nd in from left)
the coil connection
Old Aug 9, 2004 | 04:02 PM
B11GNS's Avatar
B11GNS
The thing is it works ok its just reading less then it should
Old Aug 9, 2004 | 04:11 PM
Matt's Avatar
Matt
so not working ok then
under reading would be a symptom of a poor signal from the coil, the stuff above will help you trace the wire for any breaks
if you know how to measure resistance then do that from the coil end of the cable to the clock multiplug end
could always just run your own cable from the clocks direct to the coil (like i have)
Old Aug 9, 2004 | 04:44 PM
B11GNS's Avatar
B11GNS
Will try that, cheers
TPM961
Jan 15, 2018 10:50 AM
Sierrasideways
Oct 8, 2015 06:37 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
Rammer46
Sep 18, 2015 08:31 AM
Flateric_2002
Sep 15, 2015 08:41 AM
