COSSIE WOUNT RUN WHY ????
Old Jun 3, 2006 | 04:10 PM
STUCOS's Avatar
STUCOS
Default COSSIE WOUNT RUN WHY ????
Right folks just put my rebuilt motor back in my 3dr,but the dam thing wount start,if you remouve cooler pipe to throttle body and pour some petrol down it will run till all petrol is used up,had the injectors out and wound over but there doesnt seem to be much fuel coming out of them,car is still on L1 with standard injectors,any ideas ppl
cheeRS stu
Old Jun 4, 2006 | 09:42 AM
foreigneRS's Avatar
foreigneRS
Testing the future
need more ideas than that to help. for example, does the fuel pump run? do you get a spark on all 4? have you checked all your sensors are plugged in and working?
have a read of these pages first
http://www.homepages.hetnet.nl/~pete...ick_check.html
http://www.homepages.hetnet.nl/~pete...ecu_error.html
Old Jun 4, 2006 | 09:17 PM
STUCOS's Avatar
STUCOS
Yes mate,fuel pump does run,spark at all 4 plugs,plenty compression,if fuel rail and injectors are lifted off together and you wind over engine,all 4 injectors fire in sequence,but not much fuel sprayed out,have tried 2 sets of injectors
cheeRS stu
Old Jun 4, 2006 | 09:44 PM
foreigneRS's Avatar
foreigneRS
Testing the future
ok, that sounds not too bad for a start.
have you connected the ht leads in the correct order and aligned the distributor correctly? it's quite easy to be 180 degrees out.
as a quick check, align your crank pulley before tdc just before the rotor arm is due at the marker on the dizzy body. with the ignition on and all plug leads removed, check that as you move towards tdc, no.1 sparks at the right time. rotate the crank half a turn and no. 3 should fire. another half turn and no. 4 should fire and another half turn for no. 2
Old Jun 4, 2006 | 09:53 PM
STUCOS's Avatar
STUCOS
Yes mate,plug leads on correctly and ignition timing spot on,was thinking it,s a fuel pressure problem as when you manually feed engine is pour petrol in to throttle body she runs no problem till all fuel is burnt,
cheeRS stu
Old Jun 5, 2006 | 08:55 AM
Dave Henshall's Avatar
Dave Henshall
when was the last time u changed the fuel filter..... could be a bad supply to the pump and its running at a much reduced voltage = reduced fuel flow and pressure.... combine this with an old filter that may well be blocked = even less fuel to the injectors.... another favourte,, if its been jacked up wrongly from underneath, the fuel pipes to/from the tank may have been squashed = no fuel to the injectors...
a few more ideas....
Old Jun 5, 2006 | 09:05 AM
STUCOS's Avatar
STUCOS
Hi dave,thinking now that the pump might be low on pressure as engine has been out for over 2 yrs going to replace filter and pump and see wht happens
cheeRS stu
Old Jun 5, 2006 | 10:21 AM
KSA-Cossie's Avatar
KSA-Cossie
That's a cunt stu hope it's an easy fix m8.
Old Jun 5, 2006 | 10:27 AM
STUCOS's Avatar
STUCOS
Kev maybe some tennants might fix it,why arnt you at work you8 skiver
cheeRS stu
Old Jun 5, 2006 | 10:33 AM
KSA-Cossie's Avatar
KSA-Cossie
I've got 46 bottles of miller in the kitchen m8
Cos im skiving and if i thought i'd get away with it i'd come through
Old Jun 11, 2006 | 08:32 PM
STUCOS's Avatar
STUCOS
Right guy's fitted brand new group a pump and filter today ,also a fuel pressure gauge,and it is still the same,turn on ignition and pump fires up,showes about 4.5 bar,try to start and no chance,put some petrol down throttle body and she fires no problem,and shows 3.5 bar on pressure gauge,could the phase sensor bet faulty
cheeRS stu
Old Jun 12, 2006 | 06:54 AM
Dave Henshall
hmmm, so the fuel is stil not getting to the donkey,,, could be a duff ecu.... have you had it connected to a battery charger without disconnecting the battery first...?
Karl 3dr
102
Oct 14, 2016 08:17 PM
carlo
24
Oct 5, 2015 08:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Red_bull
Aug 9, 2015 08:34 AM
lockie
Jul 31, 2015 10:03 PM
