my car cutting out
Old Jun 1, 2006 | 10:24 PM
GazzaG's Avatar
GazzaG
Default my car cutting out
my car starts fine everyday will drive ok ect just i have to tap the excelerater as soon as i move my foot it cuts out
is it cause of a cold engine ?
its a 1998 escort 1.6 zetec
Old Jun 2, 2006 | 09:16 AM
robbyridz's Avatar
robbyridz
my escort 1.8 used to do that, and it was an on going saga for 6 months
finally found it was the plastic inlet manifold which was leaking.
is probably down to an air leak, could be idle control valve sticking... no air is getting through, and then it cuts out.
spray wd40 around your different vacume hoses and roundthe inlet manifold - see when the revs climb!
is it all right once you've driven it for a couple of miles and the engine temp is up?
Old Jun 3, 2006 | 12:18 AM
GazzaG's Avatar
GazzaG
Yeah its fine after its been running
Old Jun 5, 2006 | 11:48 PM
robbyridz's Avatar
robbyridz
i'd listen carefully for any hissing noises, particularly around the inlet manifold at the back of the engine.
next step would be to clean and lubricate idle control valve, it seems to be a common problem (it wasn't which caused mine, but no 2 engines are the same )
if that doesn't sort it, get your ecu scanned by a local garage - could be any1 of many sensors.
if that doesn't solve it - check the inlet manifold for leaks - means taking it off, inspecting very carefully, lots of holding up to the light, etc, replacing gasket etc, and they shouldn't normally fracture (potentially a big job - mine took me best part of a day!)
Old Jun 11, 2006 | 12:08 AM
GazzaG's Avatar
GazzaG
Arr Cheers fella will do that when i can be botherd to mess
or ill get a garage to do it if its cheap and easyer
Thanks again
Fordmad!
Sep 26, 2015 05:24 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
john_3.0s
Aug 15, 2015 07:44 AM
track.focus'd
Aug 12, 2015 05:53 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
