Temp stopping leaks
Old Jun 1, 2006 | 07:50 PM
Shandy-Ade's Avatar
Shandy-Ade
Default Temp stopping leaks
Hi, anyone have any tips how to stop a leaky radiator until i can source another, i've tried loads of rad weld but still no good, or if anyone has a rad for a FRST let me know
Old Jun 1, 2006 | 08:01 PM
phil_focus's Avatar
phil_focus
how bad is the leak? if its not that bad i would have said rad weld would do it but other than that get a new one.
also where is it comeing from, the hoses or the radiator itself?
Old Jun 1, 2006 | 08:15 PM
Shandy-Ade's Avatar
Shandy-Ade
It's quite bad it streams out, i was changing my manifold gasket and hit the heat shield on the rad and made a hole in it, yeah it's coming from the rad itself, i cant seem to find another rad, i've been offered a xr2i/si rad but i'm sure it will be different?
Old Jun 1, 2006 | 08:47 PM
phil_focus's Avatar
phil_focus
well arent you the fool then, lol.
could you perhaps put some tape on to at least slow down the leak so the rad weld can try and have some effect?
then when it stops leaking you can peel back the tape a bit till it starts leakin again and put more rad weld and repeat this process till it is patched up. will only be temporary until you can source a new radiator ASAP!
just an idea mate, it may not even work.
Old Jun 2, 2006 | 05:55 PM
SafeChav's Avatar
SafeChav
Egg whites are good for stopping leaks believe it or not.........depends how bad the leak is though.
Old Jun 7, 2006 | 10:03 PM
Number1's Avatar
Number1
wynns cooling system stop leak. will stop it gushing out, used 3 cans in a month on my old clio 16v until i had the money for a new rad works for a while, not a permanent fix tho, i tend to stay away from radweld, killed my thermostat on my clio.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Fudgey
21
Sep 30, 2015 06:19 PM
