OVERHEATING FRST HELP PLEASE
Old Aug 9, 2004 | 11:46 AM
IANS2RST's Avatar
IANS2RST
Default OVERHEATING FRST HELP PLEASE
so far I have replaced...
headgasket twice
cylinder head
radiator
removed the thermostat
water pump
oilcooler
there are no leaks and the water & oil are not mixing, compression is the same on all cylinders.
After all this it STILL OVERHEATS
anyone got any ideas?
Old Aug 9, 2004 | 11:49 AM
Stu @ M Developments's Avatar
PassionFords Creator
What are you calling overheating?
Giove us a scenario and desciption of events pal
Old Aug 9, 2004 | 11:50 AM
soulweavers's Avatar
soulweavers
Do a pressure test of engine & cooling system, not expensive. Air lock in cooling system ?, crack in engine block ?, gasket leaking ?, water pipe blocked ?. Radiator check for blocks and flow ?.
Old Aug 9, 2004 | 12:04 PM
IANS2RST's Avatar
IANS2RST
engine warms up normally fan cuts in and the temp keeps rising.
does it even quicker if you set the heaters on cold.
I have flushed the hole system & there are no blockages.
last gasket that i removed didn't apper to have been leaking
no smell of antifreeze from exhaust or any steam
no water in the oil or vice versa
compression on cylinders are approx 13bar
Old Aug 9, 2004 | 12:11 PM
sticky_vikki's Avatar
sticky_vikki
Exactly exactly the same problem as mine is having but i dont have the patience so am stripping it
Old Aug 9, 2004 | 12:13 PM
IANS2RST's Avatar
IANS2RST
this might be going the same way
Alvyn's Avatar
Alvyn
Old Aug 9, 2004 | 12:15 PM
sticky_vikki
Noooooooooo not the beautiful Black one?
Old Aug 9, 2004 | 12:16 PM
IANS2RST's Avatar
IANS2RST
no the grey 1, black 1 never gives any trouble only shit fuel consumption
GUZZLER's Avatar
GUZZLER
could be the rad blocked, just because the water flows through it dosn't mean that the channels arn't blocked.
or could be an airlock.
Old Aug 9, 2004 | 12:54 PM
Does it overheat on teh move or just when stationary?
Old Aug 9, 2004 | 01:22 PM
GavStyli's Avatar
GavStyli
Kasapis
how olds your rad?
Old Aug 9, 2004 | 02:55 PM
IANS2RST's Avatar
IANS2RST
if you leave it idling the temp still goes up but the fan seem able to control it, doesn't go down enough for the fan to cut off. when driving the temp goes up a lot quicker.
The rad has been changed for a good secondhand 1 which i flushed before fitting
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
bigryrs
Sep 5, 2015 02:57 PM
rsturbo27
Sep 1, 2015 09:54 PM
bigryrs
Aug 28, 2015 05:32 PM
