Are Cosworth main & big end bearings the same as pinto ?
Old Jun 1, 2006 | 10:34 AM
Mk2_2dr_2L_Escy's Avatar
Mk2_2dr_2L_Escy
Default Are Cosworth main & big end bearings the same as pinto ?
Hi, I am rebuilding my cossie bottom end at the moment and being from Australia cosworth parts are not available here, although we had pintos in escorts and cortinas so pinto bearings are available.
I know that the cossie crank is the same dimensions as the pinto crank, so does this mean that there is no difference between pinto bearings and cossie bearings ?
Any help would be appreciated
Thanks,
Damion
Old Jun 1, 2006 | 11:20 AM
Gavan Hood's Avatar
Gavan Hood
I am in Australia too and am about to ship a half container of cossie parts... maybe I can help you get the parts....
Old Jun 1, 2006 | 01:04 PM
DAN P's Avatar
DAN P
pm matt lewis he might be able to help m8
Old Jun 1, 2006 | 03:48 PM
pee vee's Avatar
pee vee
only use proper Vandervell bearings !
Old Jun 1, 2006 | 05:41 PM
DAN P's Avatar
DAN P
as above
Old Jun 1, 2006 | 09:27 PM
cossie604's Avatar
cossie604
^^^^^ But.........why??? What if any differences are there between pinto and cossie?
Old Jun 1, 2006 | 09:36 PM
pee vee's Avatar
pee vee
ummmmmmmmmmmm
i think its more to do with the differences in what the crank is made from, or how its finished.
not sure, but i was told by bluesprint among other places to only use
glacier vandervell, (standard ford bearings in YBs)
just passing on the info the people in the know told me
Old Jun 1, 2006 | 09:48 PM
richm's Avatar
richm
Phil, Pinto bearings are also available from Vandervell, there must be more to it than material alone..
Old Jun 1, 2006 | 09:51 PM
pee vee's Avatar
pee vee
yea this is true!!
maybe the cosworth Yb ones are harder wearing than the pinto ones
as there is obviously gonna be more force put through them than the pinto unit??
Old Jun 2, 2006 | 05:56 AM
Mk2_2dr_2L_Escy
Cheers fellas
Old Jun 2, 2006 | 05:58 AM
Mk2_2dr_2L_Escy
Thanks for the offer Gavan, but with something small like big end bearings it's easy enough for them to be sent in the post
Cheers.
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
Blown Hell
Aug 5, 2015 07:22 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
