fuel pump priming
Old May 31, 2006 | 03:47 PM
sime73's Avatar
sime73
Default fuel pump priming
should the fuel pump prime each and every time the ignition's turned on regardless if the car fires/starts/runs or not?
Sime
Old May 31, 2006 | 03:49 PM
Rick's Avatar
Rick
providing the ignition has benn off for a few seconds.
The prime part of the fuel pump relay fails a lot.
Old May 31, 2006 | 04:17 PM
sime73's Avatar
sime73
ok thanks for that, i just got a multimeter on it and it wasn't giving power to the pump when cranking everytime so i think its faulty
Old May 31, 2006 | 05:09 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
they dont always, early cars ive had do but then both my 90specs wont if it hasnt turned over and thus used some pressure
Old May 31, 2006 | 05:32 PM
Rick's Avatar
Rick
thats still a fault with the relay, it's common.
Old May 31, 2006 | 05:49 PM
sime73's Avatar
sime73
mmm surely it must be faulty if its not powering the pump when cranking ?
Old May 31, 2006 | 06:15 PM
andyt's Avatar
andyt
mine dont not all the time and its bob on
Old Jun 1, 2006 | 12:24 AM
SafeChav's Avatar
SafeChav
The relay should always prime when the ignition has been off for about 10+ seconds. If you turn it back on before 10ish seconds it wont prime. Anything after that and its faulty, although the prime wont stop the car running but may make cold starting poor.....
Old Jun 10, 2006 | 11:50 AM
sime73's Avatar
sime73
got a new one from ford and sorted it...Ł30
Old Jun 10, 2006 | 11:54 AM
James Raby's Avatar
James Raby
they do sting you dot they
Old Jun 11, 2006 | 12:04 AM
TURBO BOI's Avatar
TURBO BOI
mine never starts on cold first time, takes afew cranks, reckon this could be due to the relay?
where is the fuel pump relay?
Old Jun 11, 2006 | 07:26 AM
HORNETS7's Avatar
HORNETS7
under driver side foot well tucked up under dash the big pink one!
Old Jun 11, 2006 | 09:35 AM
TURBO BOI's Avatar
TURBO BOI
Old Jun 11, 2006 | 11:59 AM
SafeChav's Avatar
SafeChav
TURBO BOI i doubt very much its the relay.
Try unplugging your cold start injector if it isn't already.
Old Jun 11, 2006 | 03:10 PM
TURBO BOI's Avatar
TURBO BOI
doesnt start at all with that disconected, just dies with it off
Old Jun 11, 2006 | 03:19 PM
SafeChav's Avatar
SafeChav
When you say it dies??? but you say it doesn't start at all?
Old Jun 11, 2006 | 04:08 PM
TURBO BOI's Avatar
TURBO BOI
it will run once for mayb for 1 second and die, if i try to start again it will jus crank and crank and nothing happens untill i reconnect the cold start valve then it will start with more cranking but still not on the key. hot start is fine tho always on the key
fitting efi in afew weeks anyway but thought if it had been the relay it would have be nice for it to start first time for the last few wks on mfi
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
