1900 CVH???
ok so you need ...pistons, sodium filled exhaust valves in the std head you have, and an oil return for the turbo drilled in the block, and possibly a cam depending on what you have....
Pistons and oil return needed although it does depend on the source of your 1.9. You won't need sodium valves although again what head have you got there? If you've got an American block I can help with details, as I used to import them. Good Luck
mk3ste
Oct 17, 2021 10:09 AM
