gearbox fault?
Old May 29, 2006 | 11:23 AM
fiestaturbo1984's Avatar
fiestaturbo1984
Default gearbox fault?
hey my recently acquired frst has a bit of a dodgy gearbox i think, for some reason you can go from 5th straight into reverse. i dont know whether it is hte box or linkage or whatever????
but i need help as very soon im gonna have no reverse gear
Old May 29, 2006 | 11:26 AM
SafeChav's Avatar
SafeChav
Hmmmmmmmm............i bet you, a jam tart, the gearbox has gone in the past, and its had an early BC box fitted, the early ones have no gate in the box, its down to the linkage......so with no gate in the box or linkage.......voila (crunch crunch)
Old May 29, 2006 | 03:29 PM
fiestaturbo1984
how would i tell other than the obvious thing ive stated?
Old May 29, 2006 | 03:35 PM
SafeChav's Avatar
SafeChav
Part number maybe (no i dont know the codes )
Old May 29, 2006 | 03:54 PM
fiestaturbo1984
doh, well ill have to go out and get dirty it seems, but it still feels as though there is something wrong as trying to move between the gates its quite stiff. i mean when its in neutral
Old May 29, 2006 | 07:16 PM
SafeChav's Avatar
SafeChav
Getting dirty it is
Old May 29, 2006 | 08:04 PM
fiestaturbo1984
thanks for your help
lol
Old May 30, 2006 | 06:00 AM
JesseT's Avatar
JesseT
Check the hole through which the clutch cable cable goes on top of the gear box. One single hole -> early BC box with no gate. Two alternative holes -> later type BC box with a gate for reverse.
Old May 30, 2006 | 09:27 AM
SafeChav's Avatar
SafeChav
At least someones on the pulse
Completely forgot about that good idea
Old May 30, 2006 | 09:45 AM
biglee's Avatar
biglee
Audio specialist
ahhhh answered my question, this is why i sometmies go from 5th to 4th and hit the reverse gear....cuuurrrruuunnncccchhhh, i thought my gbox was fooked...but i guess its not then......only just had it re-built, thought me mate had made a boo boo..lol
Old May 30, 2006 | 09:48 AM
SafeChav's Avatar
SafeChav
Lee it can't work that way round on your car unless you have a MK4 linkage........although its not un-common for the linkages to be so loose on a MK3 that the gate doesn't work PMSL
The linkage in that orion of mine was SOOOO loose when going from 5th to 3rd, i would move the stick across, back up and go back into 5th
Fuckin awesome things on MK3's are linkages
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
