very weird problem need help !!!
Old May 28, 2006 | 08:20 PM
deankenny's Avatar
deankenny
Default very weird problem need help !!!
recently all my wires burnt from the ecu, so i had these replaced, and now the car sparks but doesnt actually start, i dont hear the small whizz sound when i turn the ignition on, checked ALL fuses and they r all fine, so though fuel pump so we put a charge to it and we heard it so thats working, maybe its the actual ecu bvut really cxant think of much else any1 else know maybe???
its a 95 1.6 zetec
Old May 29, 2006 | 09:42 PM
deankenny's Avatar
deankenny
no one know?/??
Old May 29, 2006 | 11:15 PM
phil_focus's Avatar
phil_focus
this sounds very strange. if i were u i would try an get a dealer or good mechanic to have a look. someone reputable!!!
Old May 30, 2006 | 03:19 PM
deankenny's Avatar
deankenny
thats the thing not got too much money at mo, when we put a live feed to the wire under the seat we hear the fuel pump working, so if its working its gotta be the ecu surely not telling it to work??
Old May 30, 2006 | 03:23 PM
phil_focus's Avatar
phil_focus
try another ecu from a scrappy off an identical car to urs unless u have been running a non-standad unit
Old Jun 1, 2006 | 08:05 PM
phil_focus's Avatar
phil_focus
how did it go, does it work yet?
could be a bad conection somwhere possibly inside the ECU
Old Jun 2, 2006 | 06:55 AM
Bullett's Avatar
Bullett
check the fuel cut off switch hasnt popped itself some how. or did it have an immobiliser on the car when they burnt out?usually these are on the fuel pump system as well,worth a look.
good luck
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
