Saph had Misfire and now won't start
Old May 28, 2006 | 12:08 PM
Cosworth-PT's Avatar
Cosworth-PT
Default Saph had Misfire and now won't start
Last night my Saph had a BIG misfire (iluminated all the street lol) and then got dead.
Engine runs well, and with compression, but won't start.
Any ideas? thanks
Old May 28, 2006 | 01:21 PM
costina's Avatar
costina
Live long and prosper!!
Try the ignition first do you have a spark at coil lead?
or could be fuel problem?or electrical,
Good luck
Old May 28, 2006 | 01:23 PM
Cosworth-PT
Checked some minutes ago and seams that fuel pump is dead. At least I don't ear it as in the past. but if it's the problem, it's common the big misfire?
Old May 28, 2006 | 02:51 PM
costina's Avatar
costina
yes that can happen
Try connecting pump direct to battery and touch terminals to try to jump it back into life?
Old May 28, 2006 | 04:06 PM
Cosworth-PT
I have fuel at the injectors but don't know if pressure is fine. I have spark on coil lead. Will switch fuel filter tomorrow and see whats happens.
Old May 28, 2006 | 04:20 PM
vyper developments's Avatar
vyper developments
Hi,
you could try checking your crank sensor plug, disconnect it and give it a clean and try reconnecting and see if that cures it.
Mike.
Old May 28, 2006 | 04:23 PM
Cosworth-PT
Crank sensor plug is the sensor itself (at the crank pulley) or anything else attached to the block/head?
Old May 28, 2006 | 04:35 PM
Cosworth-PT
re-read your post and got it, will clean it also and see. the heat here is getting my brain out of place thanks
Old May 29, 2006 | 08:55 PM
Cosworth-PT
Had a lot of tests today and still don't start.
I have sparks ONLY in 1st cilinder, all other 3 don't spark at all. Any ideia? is this a phase sensor dead or so?
Fuel pump is running well, fuel filter and spark plugs are new.
Old May 30, 2006 | 03:15 PM
TurboShed's Avatar
TurboShed
Cossiemodo
If you have spark in only 1 cylinder, seems worth looking at your dizzy/phase sensor, all cheap stuff too
Old Jun 2, 2006 | 10:28 PM
Cosworth-PT
already done. still the same
j.hammond1
30
Oct 31, 2021 05:28 PM
Bailes1992
Aug 16, 2015 07:14 PM
taylora1409
Aug 12, 2015 12:06 PM
yawiejon
15
Aug 9, 2015 06:36 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
