boost gauge?????????
Old May 27, 2006 | 01:39 PM
dj22y's Avatar
dj22y
Default boost gauge?????????
where does the little fish tank type piping go on to on a FRST???
is it the pipe that comes off the top of the dump valve??????
Old May 27, 2006 | 04:09 PM
cos jon's Avatar
cos jon
Where your dump valve vacum hose goes into you inlet manifold (it says EFI) you can T Piece your boost gauge off it there.
Old May 28, 2006 | 11:43 AM
dj22y's Avatar
dj22y
right ive fitted that, its not right tho, took it out for a spin and the gauge only gets to halfway inbetween -1 and 0 bar???? that cant be right can it???
how bg does the t piece have to be and how close do you fit it to the inlet manifold???
or is it better to put it nearer the dump valve????
i be all of this is text book and im being a fool!!!!
cheers......again!!!!
Old May 28, 2006 | 12:10 PM
dj22y's Avatar
dj22y
im not doing very well today!!!! help!!!! any ideas???
Old May 28, 2006 | 12:30 PM
cos jon's Avatar
cos jon
All i can think of is you must have a split or a leak in your vacum hose, have you got a dump valve - does that work ok ??
Old May 28, 2006 | 12:39 PM
dj22y's Avatar
dj22y
its a baileys crome jobby!!! im gonna get a bigger t piece aswell wen my bad heads gone!!!! i'll have a look and come back cheers!!!!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
