Rs turbo problems
I need a bit of help with my escrot rs turbo, its running rich (you can smell petrol from the exhaust) is this just the CO, if so can i turn it down a bit myself?
Also when you floor it the cam rattle its arse off, does this means its f**k'd.
Any help will be gratefull
The fuelling can be adjusted, on the assumption the metering head isn't fucked. You need to have it set up on a rolling road really though as they are tempermental and idle CO levels mean diddy squat on MFI.
If the cam taps etc then yea its 99% guna need a new cam n lifters. You will be surprised at how much better it drives after though
Matt Baxter
Sep 16, 2015 08:30 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
