ARP stud and nut kit
Old May 25, 2006 | 05:53 PM
pee vee's Avatar
pee vee
Default ARP stud and nut kit
do you need to machine the block to use these,
as in re-tapped??
and what power are normal head bolts ok to?
Old May 26, 2006 | 04:26 PM
pee vee's Avatar
pee vee
anyone
Old May 26, 2006 | 07:58 PM
Ian M's Avatar
Ian M
arp stud and nut kits dont need any machining of the block.
quite a few people run decent power levels with standard head bolts including karl norris. hope that helps.
Old May 26, 2006 | 11:07 PM
pee vee's Avatar
pee vee
thankyou mate!
a guy i was speaking to on the phone was telling me anything over 320 ish should be stud and nut kit time!
a good investment all the same im sure?
Karl norris is up round 700 isnt he!? or did you mean his customers!
also, did i read right, that some people have trouble with
blocks cracking when using stud and nut kits????
thanks again
Old May 29, 2006 | 12:27 PM
Ian M's Avatar
Ian M
karl uses standard bolts on his own car.
stud and nut kits wont crack blocks if they are fitted correctly. a mate of mine has used them on his car for at least the last 3 years with no probs whatsoever.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
little bram
Sep 27, 2015 07:45 AM
