Tappets
Old May 25, 2006 | 04:29 PM
The Sludge's Avatar
The Sludge
garibaldi
Default Tappets
Can you still obtain these by Ford do you know?
Old May 25, 2006 | 04:31 PM
turbo.jon's Avatar
turbo.jon
Should be able to i just got mine from local motorfacts
Old May 25, 2006 | 04:37 PM
The Sludge's Avatar
The Sludge
garibaldi
cheers bud
Old May 25, 2006 | 11:52 PM
SafeChav's Avatar
SafeChav
You can still obtain them, however, if its for a CVH don't be fooled into thinking its going to fix that noisy top end.
Cam wear chews the lifters, fit a spanker set in with your old worn cam and within minutes it will sound like it did before.
New cam and lifter time im afraid
Old May 26, 2006 | 12:02 AM
Rick's Avatar
Rick
you can get them from me....
u will need a cam to fo with them though.
Old May 26, 2006 | 01:05 PM
sufsRS's Avatar
sufsRS
got some a few weeks back ian, around 80p each, make sure its the modified type as these are alot better
Old May 26, 2006 | 01:16 PM
SafeChav's Avatar
SafeChav
HOW MUCH?????????/ Where was that from
That said i have seen some REALLY cheap shit ones that blow their caps off................and not even they were that cheap
Old May 26, 2006 | 01:29 PM
sufsRS's Avatar
sufsRS
genuine ford www.fordpartsuk even if you go to a ford dealer they wont be no more then 1.20 each
Old May 26, 2006 | 03:07 PM
Kop2381's Avatar
Kop2381
Sure your not on about valve stem oil seals
Old May 26, 2006 | 03:29 PM
sufsRS's Avatar
sufsRS
Jay your right dont know what i were thinking probably because i was doing the seals yesterday
Old May 26, 2006 | 05:01 PM
Rick's Avatar
Rick
Old May 26, 2006 | 05:05 PM
SafeChav's Avatar
SafeChav
PMSL ner ner ner ner ner
foreigneRS
Technical essay Archives
Jul 20, 2025 05:28 PM
davidfordrs
Sep 21, 2015 04:23 AM
Roosie
Aug 13, 2015 07:40 PM
foreigneRS
Jul 20, 2004 11:29 AM
foreigneRS
Jul 20, 2004 11:06 AM
