map sensor
Old May 23, 2006 | 07:29 PM
jonesymk2's Avatar
jonesymk2
Default map sensor
im changing my erst estate 2 efi soon and hav got everything out of an xr3i and will b putting the whole loom in and was wondering where the map sensor go or can it not b done with the loom.ive got an ofac frst ecu with a superchips 195 ecu if that makes any difference
Old May 23, 2006 | 07:48 PM
Rick's Avatar
Rick
Im not quite sure what ur asking...
The Map Sensor can go anywhere, as long as it is mounted facing downwards to avoid collecting any fluid.
Old May 24, 2006 | 07:29 PM
jonesymk2's Avatar
jonesymk2
sorry just had a look and i was a bit vague,what i was meant 2 say was will the xr3i loom hav a space for the map sensor or should it already hav 1 and if so what do they look like so i know what 2 look 4 in the box of bits ive got from the car
Old May 24, 2006 | 07:36 PM
SafeChav's Avatar
SafeChav
The XR3i loom will have a plug for the MAP, and if you are running OFAC the plug is the same. However OFAC MAPs are different to XR3i MAPS.
Old May 24, 2006 | 07:40 PM
jonesymk2's Avatar
jonesymk2
ok then,ive got an ofac ecu so what map sensor would i need 2 get
Old May 24, 2006 | 07:59 PM
SafeChav's Avatar
SafeChav
The MAP sensor for OFAC
Old May 24, 2006 | 08:05 PM
jonesymk2's Avatar
jonesymk2
ok silly question really i suppose would i b able 2 get a 3 bar map sensor and what advantages would this hav and roughly how much would 1 cost
Old May 24, 2006 | 08:28 PM
SafeChav's Avatar
SafeChav
I dont think you can get higher pressure MAPS, this being the reason most people run OFAB, cos they use the Marelli MAP, so you can bung a coosie 3 bar jobber on
Old May 25, 2006 | 12:06 PM
jonesymk2's Avatar
jonesymk2
so basically ive just got 2 get a standard 1 from sumwhere
Old May 25, 2006 | 12:16 PM
SafeChav's Avatar
SafeChav
Yea, a standard OFAC MAP. Looks identical to the XR3i one.
Old May 25, 2006 | 04:35 PM
jonesymk2's Avatar
jonesymk2
would it b worth maybe trying ebay 4 1
Old May 25, 2006 | 05:04 PM
SafeChav's Avatar
SafeChav
Be cheaper than ford
Old May 25, 2006 | 05:11 PM
jonesymk2's Avatar
jonesymk2
yeh i got a mate that works in a motorist centre 2 get me a price from 1 of there suppliers and that was 60quid
Old May 25, 2006 | 05:22 PM
SafeChav's Avatar
SafeChav
Fuck that, seriously if i were you i would go OFAB, u can get a Marelli 3 bar sensor for £55 new!!!!!!!
Old May 26, 2006 | 05:36 PM
jonesymk2's Avatar
jonesymk2
the thing is ive only just bought an ofac ecu the other weekend
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
