how to get turbo chatter,flutter etc
Old May 22, 2006 | 09:47 PM
xr2.0zetecturbo.'s Avatar
xr2.0zetecturbo.
Default how to get turbo chatter,flutter etc
any ideas how to get it basically?currently running 2l zetec t3, estimate on costs,parts required,any benifits besides the bulge that u get down below when you here it,(or the excited twitch if youre a gal,i hope) would love to have it,just a few ideas if its within budget,thanx
Old May 22, 2006 | 10:40 PM
SafeChav's Avatar
SafeChav
What management are you running. MFI is classic for deadening the sound. All chatter is, is turbine stall. If you have a DV then u won't get chatter, and even if u did the DV would drown it.
Old May 22, 2006 | 10:41 PM
cossie350's Avatar
cossie350
Cone filter and run bit more than standard boost, hey presto. No benifit from what ive heard it dont do the turbo much good, better off with a dump valve. Hope this helps
Old May 22, 2006 | 10:42 PM
cossie350's Avatar
cossie350
Old May 22, 2006 | 10:43 PM
cossie350's Avatar
cossie350
Anyone know why this fucker keeps happening everytime i post i get an echo
Old May 22, 2006 | 10:50 PM
SafeChav's Avatar
SafeChav
Old May 22, 2006 | 10:51 PM
cossie350's Avatar
cossie350
Old May 22, 2006 | 10:52 PM
cossie350's Avatar
cossie350
Sorted dont know what i did but it worked
Old May 22, 2006 | 11:13 PM
xr2.0zetecturbo.
not sure what managements on it,standard i think,mfi??? nothing programable/mappable like the aftermarket stuff as i was told to get some on it to increase power/performance,yeah it has dv on,like a load of 306 td's near me so getting fed up of hearing em,wanted summat different especially as it works almost as good as viagra 4me when i hear it!!!or summat big to drive over the 306's lol,has adjustable boost from inside car,just gotta turn and turn it ..... wish i had a clue bout this and loads of other stuff on car,bought it as it is now,almost as hard as getting a gold member logo lol,thanx guys,gonna give it a go
Old May 22, 2006 | 11:29 PM
SafeChav's Avatar
SafeChav
Get rid of the MFI firstly, along with that bleed valve in the car UNLESS you have a second bleed valve under the bonnet to limit what the incar one does. If the in car one is working as a stand alone then you have the ability to turn your engine into scrap!!! Be VERY VERY VERY VERY careful how far you are turning it..........
Old May 23, 2006 | 10:04 PM
xr2.0zetecturbo.
mmmm,take that to heart then and seek out sum1 to have a look at whats actually on it,lad just told me its efi management???that right?know the adjuster 4 the doost does wind out bout 10-12 times,maybe more till its fully out,getting rid of dump valve sounds a good starter and go from there,thanx guys
Old May 23, 2006 | 10:18 PM
SafeChav's Avatar
SafeChav
Get a picture of the engine bay and i can tell you what you are running.
In-car bleed valves can be shocking things, i dont think most people release how deadly they are and how much damage u can do with one. Most of them, from closed, only open up about 1 turn to full adjustment. Its DEFINATELY worth getting that checked out, and even disconnecting it for time being if u feel the need.
Keep us posted
Old May 24, 2006 | 07:52 AM
DanS's Avatar
DanS
Dont mean to open a massive can of worms but...............
Does the compressor wheel really stall? The way i think of chatter is if you spin a fan and blow through it the wrong way u get a whirling noise. If the fans stopped or "stalled" and you blow through it, it makes very little noise....
My point is, i dont think chatter comes from the compressor wheel stalling, more likely air rushing past it in the wrong direction and the blades chopping the air as it goes past!
ok i'll get my coat
Old May 24, 2006 | 12:17 PM
Avinitlarge's Avatar
Avinitlarge
Depends how you work the throttle, I could make mine dump, chatter or dump and chatter
Old May 24, 2006 | 09:20 PM
xr2.0zetecturbo.
mmm,pics,got sum,how the hell you get em up thou???trying to get this photo bucket thing working, think even i could get layed easier than figure the pic thing out,mind you,not as much stress as the car,lol
Old May 24, 2006 | 11:13 PM
SafeChav's Avatar
SafeChav
What are you trying to do.
Once your set up on photo bucket, and the photos. Once done underneath is 3 labels, copy and paste the IMG one into a post on here and voila........
Old May 24, 2006 | 11:34 PM
LEE-RS's Avatar
LEE-RS
Custom
you know how a turbo works the turbine spins the compressor on the same shaft you shut the throttle the air (boost) hits the shut throttle reverses the air trys to spin the compressor the opposite way then you get whats called the chatter sound which in the end can snap your shaft in half
Old May 24, 2006 | 11:37 PM
SafeChav's Avatar
SafeChav
So then, LEE-RS, what sort of noise will it make when the shaft snaps
Old May 24, 2006 | 11:48 PM
LEE-RS's Avatar
LEE-RS
Custom
i dont know never had it happen to me people on here say it dont do fook all to your turbo but its not gonna do damage on low miles as the standard turbo can last upto 100k + remember when the the air (boost) is trying to push the compressor the opposite way the turbine is is still being pushed the right way from the exhaust gas so in the end it comes down to whos the strongest
Old May 24, 2006 | 11:53 PM
SafeChav's Avatar
SafeChav
Theres so much controversy about all this. To be honest though, all the fast RS's ive seen don't have them, and track cars can usually be heard chattering. The ruling as i understand it is unless you are running 10+psi of boost or have a T4 or bigger then its safe. god knows
SafeChav's Avatar
SafeChav
Oh and by the way asking about the noise it makes when the shaft snaos was a joke lol, OBVIO
Old May 25, 2006 | 12:02 AM
LEE-RS's Avatar
LEE-RS
Custom
a dump valve dont give chatter because it lets the air (boost) out after its reversed before it hits the compressor
Old May 25, 2006 | 11:55 AM
SafeChav's Avatar
SafeChav
You can make a car with a DV chatter but its very hard
Old Jul 21, 2006 | 07:57 PM
FelthamRST's Avatar
FelthamRST
so how can a car chatter with a dumpvalve then?
Old Jul 21, 2006 | 07:58 PM
_DAN_'s Avatar
_DAN_
Yoon
is this wastegate chatter..........
Old Jul 22, 2006 | 08:50 AM
SafeChav's Avatar
SafeChav
Its not very easy to do, you have to come off the throttle in such a way that the car drops boost but doesnt go into vacuum so the DV doesnt open.
Was coming back from weston last year with my mate in his R5 GTT, he had a T3 Roller on it and a Forge diaphram dump valve, and he was moaning he couldnt drive on the motorway without the turbo boosting (being a roller) so he was dabbing the throttle and realised he could make it chatter without the DV going off, and i joke you not i fell asleep and woke up about 3 quarters of an hour later and he was still still doing it with the same chuffed as fuck look on his face PMSL
Old Jul 22, 2006 | 09:59 AM
gambit's Avatar
gambit
Default chatter
i have a dump valve and it has been heard faently on my car many times
Old Jul 22, 2006 | 10:15 PM
FelthamRST's Avatar
FelthamRST
ok so if i took off the dumpvalve to get the flutter (which i did the other day and was kinda loud) i heard it can damage the turbines. what is the likelyness if that happening or happening any time soon? i would like to drive around for a while with the flutter but cant afford a new turbo right now lol. cheers guys!!
Also... does any1 know whats involved in reboring my engine to something bigger than 1..6? what else has to be done and costs? cheeRS!!!!!
Old Jul 23, 2006 | 06:58 AM
reality's Avatar
reality
You dont need a dump valve unless you're running a big turbo.. It's not really relative to how much boost you're running either.. You can quite happily run 2 bar boost on a T34 without a dump valve.. Also, when the pressure wave (chatter) does break a suitable turbo, it usually damages the compressor wheel, not snap the shaft..
Old Jul 23, 2006 | 10:47 AM
SafeChav's Avatar
SafeChav
Indeed as reality says, in practice unless you are running more than about 30psi of boost or T4 or bigger, then dump valves arent required
Old Jul 24, 2006 | 09:51 AM
LEE-RS's Avatar
LEE-RS
Custom
theres a good explanation here by stu about turbo chatter/surge
https://passionford.com/forum/viewtopic.php?t=34511
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
