s2 clock memory
Old May 22, 2006 | 08:09 PM
©hatter Box's Avatar
©hatter Box
Default s2 clock memory
as up top i set the time and every time i start the car it loses the time and have to re enter what is that down to?
Old May 22, 2006 | 08:13 PM
Oranoco's Avatar
Oranoco
Operator error
Could be a duff clock unit, can you swipe the one out the missus cabby and see if that does the same thing? If it doesn't put yours in her car and deny everything
Old May 22, 2006 | 10:33 PM
SafeChav's Avatar
SafeChav
Originally Posted by Oranoco
Operator error
Clearly a brave man
The plugs have a yendency to work loose over the years, worth a check
Old May 22, 2006 | 10:40 PM
©hatter Box
Operator error
I would have no balls left if i did do that have swaped for 3 now and have the same shit i mite have to just put up with it lol
Old May 22, 2006 | 10:42 PM
SafeChav's Avatar
SafeChav
Thats very wierd because of the clock works it should be accurate, and i cant see 4 clocks being faulty. Have you checked there is 12v there?
Old May 22, 2006 | 10:44 PM
©hatter Box
will give it a go at weekend if i get time but i got to get this 4x4 fucking done and this frst sitting on my drive
Old May 22, 2006 | 10:48 PM
SafeChav's Avatar
SafeChav
Ill take the FRST away free of charge if its in the way
Old May 22, 2006 | 10:58 PM
©hatter Box
well it got no engine in it or gearbox in it. just sitting up in the air: filling sorry for its self cry:
Old May 22, 2006 | 11:01 PM
SafeChav's Avatar
SafeChav
Bet its rapid with all that weight you're saving
Old May 22, 2006 | 11:11 PM
©hatter Box
just wish i could do the same with the cabrio
Old May 23, 2006 | 04:34 PM
JamboRS's Avatar
JamboRS
focus rs 1672
does it turn off when you switch car off?
Old May 23, 2006 | 05:59 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
The clock should be perm on so if it goes off, then it isn't wired direct to live and should be. (You should only be able to adjust the clock when the ignition is on btw..but is 'viewable' all the time)
Old May 24, 2006 | 09:17 AM
neilrev's Avatar
neilrev
could the starter motor be drawing too much current when starting, taking power away from other things e.g. the clock. just a thought.
Old May 24, 2006 | 05:33 PM
©hatter Box
spot on
Old May 24, 2006 | 05:40 PM
JamboRS's Avatar
JamboRS
focus rs 1672
theres your problem,
take it out,check/clean all connectors make sure your gettin power from it when turning off
if your not your gonna need to find the breakdown,ive known for people to fit pods in the a pillar and it can touch the wires goin up it to the clock
have you got a pod
Mark_
14
Jan 16, 2016 05:27 PM
Mr S1
20
Sep 27, 2015 04:06 PM
DAN@ADRIAN FLUX
37
Sep 20, 2015 10:38 AM
