Maram shaft?
Old May 22, 2006 | 12:52 PM
costina's Avatar
costina
Live long and prosper!!
Default Maram shaft?
Just wondered how you check if you have a maram shaft in your turbo?
I was told there non magnetic is this true ?
As i've tried this and yes it is non magnetic
I know there are numbers to look at but i cannot be bothered to take exhaust off to check.
Do I have one or not?
Old May 28, 2006 | 02:45 PM
costina's Avatar
costina
someone must know?
Old May 28, 2006 | 09:04 PM
SafeChav's Avatar
SafeChav
Apparently not?
To be honest, i think the shafts in all turbos are stainless, and stainless isn't magnetic. Im not 100% though
Old May 29, 2006 | 07:03 AM
Speedy G.'s Avatar
Speedy G.
Maram is indeed non magnetic and their should be 247 on the shaft somewhere.
I think those are the only ways of telling you've got a maram shaft.
Old May 29, 2006 | 09:52 AM
SafeChav's Avatar
SafeChav
IS 247 the grade of steel used then?
Old May 29, 2006 | 03:13 PM
Mr C's Avatar
Mr C
247 is pressed into the back of the shaft, the only other way to be certain mate is to remove exhaust
Fudgey
21
Sep 30, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
IainRS1700T
Sep 25, 2015 06:44 AM
rsstav
Sep 7, 2015 04:43 AM
