MT75 Quickshift?
Old Aug 7, 2004 | 07:46 PM
James's Avatar
James
Default MT75 Quickshift?
Is this easy to fit, how do you fit? - Is it a box out jobbie?
Where can i get one? - Are they actually any good?
Old Aug 7, 2004 | 08:00 PM
Billabong's Avatar
Billabong
If you've access to a ramp, you can get away with lowering & supporting the box to fit one.
Old Aug 7, 2004 | 08:17 PM
slowpoke's Avatar
slowpoke
just had one fitted to my saph
i didnt do it i had it fitted while the clutch was being done
i got just the knuckle bit from woddford and think its better than the normal shift now that its wearing in
Old Aug 7, 2004 | 09:25 PM
rstoughy's Avatar
rstoughy
http://search.ebay.co.uk/cosworth-qu...W0QQsoloctogZ9
Old Aug 8, 2004 | 05:44 PM
James's Avatar
James
Drop the box?
Fook doing that!.. I ws thinking it was more a case of swapping the selectors around!
Old Aug 8, 2004 | 05:45 PM
SPADGE's Avatar
SPADGE
They make very little difference imo!
Old Aug 8, 2004 | 05:49 PM
Billabong's Avatar
Billabong
Originally Posted by James
Drop the box?
As in lower slightly & support - it is normally a box out job for the 4x4 box.....but can be done like I said above if you have access to a ramp.
Old Aug 8, 2004 | 05:52 PM
SPADGE's Avatar
SPADGE
They can actually be fitted from inside the car Bill!
Just remove the centre console etc...and remove the big circlip that holds the knuckle in place and Bills your uncle
But as i said they make very little difference!
Old Aug 8, 2004 | 05:55 PM
Billabong's Avatar
Billabong
Without lowering the box at all? Maybe a slightly different matter on your modified 2wd-4x4 tunnel perhaps....??
Old Aug 8, 2004 | 06:00 PM
SPADGE's Avatar
SPADGE
Its a little fiddley Bill but can be done i am sure
Old Aug 8, 2004 | 06:12 PM
dave cos4x4's Avatar
dave cos4x4
SPADGE,
What about the bolt that goes through the knuckle.
This is inside the cradle that bolts to the box that is difficult to get at, hence lowering the box or taking the box out.
Dave.
Old Aug 8, 2004 | 06:16 PM
trevCOSS's Avatar
trevCOSS
Your absolutely right, although I did mine without lowering the box, however I wouldnt recommend it cus it was a nightmare, no access for spanner!!!! But i think it was well woth it, gives a nice feel but doesnt really help change gear faster just feels nicer
Old Aug 8, 2004 | 06:17 PM
SPADGE's Avatar
SPADGE
You can get to this bolt through the hole in the tunnel
Like i said it is fiddley
mjonathan24
Oct 29, 2015 10:39 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie brad
Sep 29, 2015 02:38 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
Old ford
Jul 31, 2015 06:50 AM
