Mfi fuel pump
Old May 21, 2006 | 12:37 PM
White RS1600i's Avatar
White RS1600i
Default Mfi fuel pump
Is the mfi rst fuel pump the same as the xr3is etc ? Its just mine got ripped of and i need another asap.
Old May 21, 2006 | 12:38 PM
notSteveS2's Avatar
notSteveS2
mfi is external... dont think 3i 1 is...
not 100%
Old May 21, 2006 | 01:16 PM
White RS1600i
Ive got a 3i with an external i was just wondering if it would be good enough to use ?
Old May 21, 2006 | 01:18 PM
notSteveS2's Avatar
notSteveS2
hmmmmmm... not sure mateuy....
sum1 will no
Old May 21, 2006 | 02:49 PM
DazC's Avatar
DazC
The MFI RST and MFI XR3i pumps are the same.
Old May 21, 2006 | 03:49 PM
White RS1600i
Cheers mate thats alright then
Old Jun 11, 2006 | 12:35 AM
Sean Davie's Avatar
Sean Davie
it's also the same as xr4, xr4x4,2.8 capri, 2.8granda, audi 80 & 90 quattros and sum others with external pumps
Old Jun 11, 2006 | 07:28 AM
originalcabbie's Avatar
originalcabbie
There has been a post about this previously. The XR3i pumps and RST pumps are different. They flow different pressures.
The XR3i flows at 4.7 - 5.5 Bar, see below
And the turbo flows at 5.5 - 6.0 bar, see below
May need to load pics externally as they are resized and somewhat inreadable.
The XR3i pump will work but the maximum operating pressure is being used to cater for the RST fuelling. If you are running anything over standard then an RST fuel pump would need to be used.
IMO I would just go a pick up a cossie one on ebay!
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
stevierob
Sep 7, 2015 07:09 PM
