my s1...HELP! somthings drawing the battery flat????????
HELP!HELP!
just brought this series 1,guy told my it needed a battery......but batterys fine.
something is drawing currentfrom battery,wen u start it it runs fine.....turn ka off and it fails to do anything???
any 1 got any ideas??? alternator is new,earths are ok,changed starter.........im thinking it cud be the immobilser??
C ould be the small harness from alternator to starter motor this is a common fault. Also sounds silly but is the battery light illuminating when the ignition is put on? If not you may have lost a switch live from some where.
thanks for that chaps, i will check the wire from the alternator 2 startor motor,its running a series 2 engine and ive noticed that 2 red wires come out the back of the alterntor and a blue wire???but theres no where 4 the blue wire to go any ideas???
the boot light is defo not on.
latest is ive removed the immobliser,and replaced the earths.....fault still there.
Well theres your fault then, more than likely linked to the blue wire not being connected. This usually goes to the smaller live terminal on the alternator and I think it connects to a switch live usually but check first dont want to give you the wrong info!
First of all have you checked the alternator is definitely charging by puuting a volt meter across the battery. You should have 13.5v-14.2v. If its below this I would just try putting a live to the blue wire if its connected to the alternator and see if it then charges. If it does then you just need to run an ignition live to the blue wire if not
dunno
dunno
Originally Posted by cossie_wona_b
o n ive notice the battery light does come on then dims sumtimes,and when i was driving the car it dimly flashed???????????mmmmmmmmm
Have you done that current draw reading i told you to do yet?
dunno
dunno
Etch a sketch?
I'll get my coat
You are a disgrace to this forum
i finkwe av a result boyz!!!thanks for your elps!!!!
az i was changing the turbo 2day i checked the wires from the starter to thealternator ..........result the red wire wasnt making a good connection and all the wires ad got hot
so ive replaced them,and wen i moved the rad guess wot i found a blue wire on its own...........to be continied wen i build the turbo back up!!!
thank for ur elps!!!!
gona build itbk up l8r so get them fingers crossed!!!!!!!!!!!!!!!!!!!!
again thanks for ur help!!!!!!! ur legends in ur ownrights
even after all this shit im still loving the s1 az oppose to my scooby ive just sold.....cant beat an rs!!
