RS500 no.4 fuel pump problems
Old May 20, 2006 | 06:04 PM
Speedy G.'s Avatar
Speedy G.
Default RS500 no.4 fuel pump problems
A mate of mine is rebuilding his RS500 prototype no.4 and he's having troubles with the fuel pump.
He drove the car in the garage last year and now it refuses to start at all.
Is their a inertia switch like on the Esc Cos and if so, where is it?
He does have a wiring diagram of a LHD 3door but is the RS500 the same as that?
Can anybody please help us???
Old May 23, 2006 | 04:18 AM
Nick500's Avatar
Nick500
I cant think of any kill switch on the 500's. the wiring is more or less the same as the 3 doors so should be ok! maybe best to check the fuel pump relay in beside the ECU. or check the voltage at the pump it may just be kapoot.
Old May 25, 2006 | 06:45 PM
Speedy G.'s Avatar
Speedy G.
Fuel pump is fine.
We now think that the ECU is the cause of our troubles.
Old May 26, 2006 | 08:43 AM
Ryan's Avatar
Ryan
as above.
the fuel pump is trigger by the ECU via pin 28 to a Relay.
u might want to check u have a spark aswell.
I.e u might not be getting power to the ECU.
HTH
Old May 26, 2006 | 10:59 AM
topaz's Avatar
topaz
1K+ Super Poster!!
I was havign starting issues, engine would crank and crank but never fire, unless i gave it LOADS AND LOADS of fuel, then it would go with a massive cloud of smoke.
took my cosworth to jay at jj performance, he changed all the sensors and serviced it, now its sweet as a nut.
top marks jay.
im betting number 4 has a faulty or dirty sensor.
Old May 26, 2006 | 01:44 PM
fordsportjay's Avatar
fordsportjay
cheers neil,it was a pleasure to work on the car
Old May 29, 2006 | 07:23 AM
Speedy G.'s Avatar
Speedy G.
Problem solved.
The cultrip was the ECU.
New ECU and she fired the first time.
Bit strange for an ECU to pack up from standing still, don't you think???
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dlwarrior
Aug 5, 2015 10:19 AM
