which spark plugs and what gap?
Old May 20, 2006 | 01:47 AM
sjm's Avatar
sjm
Default which spark plugs and what gap?
as above, the car is a 2wd sapphire cos, low comp, 3 bar, 803's, 500 cooler etc. running a t3 which boost's too 22psi. 328bhp before missfire . i've tested the plugs, and i'm pretty confident thats the route of my trouble.
i've heard that 071's at 0.6mm would be best, am i too assume these are available from ford? and is this the best option for me? or i am best just nipping down to demon tweeks and getting shafted by some over priced option?
oppions and advice much needed.
Old May 20, 2006 | 06:12 AM
cossie604's Avatar
cossie604
http://cgi.ebay.co.uk/COSWORTH-AGP-0...QQcmdZViewItem
found them for you Im running them and imo they are a good budget option.
Stu.
Old May 20, 2006 | 07:13 AM
cossie330's Avatar
cossie330
Hi mate i just put champion c57 in on recomendation although now has a lumpy tickover, but much smoother when driving
Old May 20, 2006 | 08:33 AM
sjm's Avatar
sjm
tweeks just quoted £60 for a set of denzo iridium, are these any good??
Old May 20, 2006 | 10:15 AM
cossie604's Avatar
cossie604
lol shud hope so for 60 quid!!
Old May 20, 2006 | 10:27 AM
KSA-Cossie's Avatar
KSA-Cossie
071's are great value for the money i personally change them every time i change the oil.
Old May 20, 2006 | 12:35 PM
bud-weis's Avatar
bud-weis
Football Cwazy
i've just changed from 071's to denso iridium ik27's
the 071's are a good cheap plug but mine were pretty much done after 3k (electrode worn away)
the denso's idle very well and hopefully will last ages
Old May 20, 2006 | 08:36 PM
costina's Avatar
costina
Live long and prosper!!
pp8's all day long at 0.6 mm
Never had a problem
Old May 21, 2006 | 08:09 AM
sjm's Avatar
sjm
after speaking with a couple of local tuner's i've gone for some c57's gapped at 25 thou ( 0.63mm ) cost me £40. i was told to expect them to last between 3000 to 6000 miles.
the tick over does'nt seem as bad as i was expecting, and it feels as smooth as ever through the rev range.
cheeRS all.
Old May 21, 2006 | 08:11 AM
cossie604's Avatar
cossie604
I gave up with the c57 and c59 range...couldnt get more than 2500miles out of them.
Old May 22, 2006 | 04:33 PM
opposite lock's Avatar
opposite lock
think the c57 , c59 are more of a race plug and hi boost. ive just put a set of pp8 at 0.8mm for standard boost runs better than ever .
Old May 22, 2006 | 11:23 PM
©hatter Box's Avatar
©hatter Box
shame they dont make the 701s any more
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
