How do i convert s2 block for a frst
Old May 19, 2006 | 07:37 PM
jrs's Avatar
jrs
Default How do i convert s2 block for a frst
How do make up the crank position sensor for a s2 block
Old May 19, 2006 | 10:26 PM
SafeChav's Avatar
SafeChav
Right
Its very simple, but also quite tricky at the same time if that makes any sense at all?
The easy bit: the sensor mounts in an aluminium adapter which bolts onto the block
The tricky bit: drilling the holes ACCURATELY
Old May 20, 2006 | 08:06 AM
jrs's Avatar
jrs
Cheer's mate
Old May 20, 2006 | 10:08 AM
ian r's Avatar
ian r
taken from a old post i saved
You don't need torun and efi block as you can use a sierra 1800 cvh bottom pulley and sensor and bracket, all direct replacements of 1600 items ( The pulley just needs a skim to make it narrower to clear the inner wing ) the pulley has the 36 - 1 teeth on it like the efi flywheel does so this can be used and you won't need to change your engine, doesn't this sound a bit easier?
Shopping list
1800 cvh crank pulley,
1800 cvh alternator pulley ( Uses thicker belt )
1800 cvh alternator bracket ( Skim 4mm of the side to move alternator over towards the driver side allowing all pulleys to line up exactly )
1800 cvh cambelt cover with crank sensor in it ( cut off just above the lower two bolt holes to allow the use of original top cambelt cover )
any questions just ask !!
Old May 20, 2006 | 10:27 AM
jrs's Avatar
jrs
Shopping list
Ive got an old xr2i block that im going to dump so was going to use that as a template by griding out the bit that the sensor fit's into and put it over the s2 block so i drill it in the right place do you think it would work
Old May 20, 2006 | 10:34 AM
ian r's Avatar
ian r
email scort at http://www.escortrsturbo.co.uk/forum/ he has a template for drilling the hole he might email u a copy
Old May 20, 2006 | 10:44 AM
SafeChav's Avatar
SafeChav
Ive got measurements, its easy to measure out.
Old May 20, 2006 | 04:50 PM
jrs's Avatar
jrs
Ive got a fiesta rs turbo block that is coming out so can use for measuring
Old May 20, 2006 | 06:45 PM
SafeChav's Avatar
SafeChav
Fine then
Old May 20, 2006 | 08:43 PM
jrs's Avatar
jrs
Originally Posted by safechav
Fine then
If you want to send me some measurments to help that would be nice
Old May 20, 2006 | 11:16 PM
SafeChav's Avatar
SafeChav
No no its fine im sure your block is better
I'll hook them out and draw them up
Old May 21, 2006 | 09:21 AM
jrs's Avatar
jrs
Thank's mate
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
mondeomark
Sep 28, 2015 06:28 AM
