Mondeo Duratec ECU Mapping.....
Old May 19, 2006 | 03:02 PM
Roysy's Avatar
Roysy
Default Mondeo Duratec ECU Mapping.....
Can anyone help me....? Have a full MBE 967 ECU and need a base map for a 2.3 Duratec Engine... Any help or suggestions would be appreciated... Thanks Roy
Old May 19, 2006 | 03:46 PM
sailorbob's Avatar
sailorbob
Do you have the original ecu? If so I may be able to get the base fuel map from it.
Old May 19, 2006 | 07:52 PM
Roysy's Avatar
Roysy
Not for the 2.3 the old engine was the 2.0....To be honest havnt got a clue what i am doing....
The 2.3 engine doesnt run well on the 2.0 litre management... But maybe something I could look to adapt... How would i go about getting the base fuel map off the ecu...???
Thanks for the suggestion its a start....
Any other suggestions would be very much appreciated....
Roy
Old May 19, 2006 | 10:50 PM
sailorbob's Avatar
sailorbob
Ford ecu's are coded with the engine displacement, if you change engine size without chipping the ecu to account for this change then you do get problems as the ecu uses the engine displacement to calculate load. Load is a fundamental value used in table lookups and the value will now be wrong. If you are using a standard engine then I'd suggest sourcing a 2.3l ecu to use.
Old May 21, 2006 | 09:43 PM
Roysy's Avatar
Roysy
Cheers Sailorbob.....OK Im with you... The engine I have installed is a 2.3litre Duratec I4 with uprated cams spings etc, high compression pistons... throttle bodies... exhaust... so you can image that it doesnt run well at all on standard, but i have a MBE Ecu with loom bought second hand.. just need a base map so i can get it on the rollers....
Any help or suggestions would be very much appreciated
Thanx Roysy
Old May 22, 2006 | 09:06 AM
sailorbob's Avatar
sailorbob
OK, a stock 2.3 map would be better than you've got but still not right. I'm afraid this one's beyond what I can help with now, anyone else?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
griffo69
Oct 4, 2015 11:58 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Iain Mac
Sep 30, 2015 09:39 PM
