Injectors
Old May 18, 2006 | 04:30 PM
s2rstony's Avatar
s2rstony
Default Injectors
As im putting a new head and cam on soon i was thinking about putting a new set of injectors on as well,
should i get new standard ones or upgrade them, if so what ones?
or should i just get the oned ive got recalibrated, if so where in se london does recalibration?
cheers
Old May 18, 2006 | 04:39 PM
Lincolndanny's Avatar
Lincolndanny
is it for a s2 mate?(going by your name) if it is, then apparently standard mfi injectors are very good for flowing fuel,its the ECU that limits the fueling apparently, so if your still running MFI then stay with standard injectors
Old May 18, 2006 | 04:44 PM
addiction's Avatar
addiction
you cant get uprated injectors for MFI and the standard ones do have good flow rate anyway!
its the metering head that holds it back.
Old May 18, 2006 | 04:53 PM
s2rstony's Avatar
s2rstony
yeah its for the shite MFI on the s2.
cheers for the advice
Old May 18, 2006 | 09:01 PM
JimmyBoy's Avatar
JimmyBoy
AFAIK the metering head / injectors can supply upto 250bhp (on a well setup car), dont know how much more the injectors could flow beyond this, as again it's the metering head that is the limiting factor here.
If you are below this amount of power (most likely) then solong as it is "chipped" then I think you will be ok, im sure someone will correct me if I am wrong.
Old May 18, 2006 | 09:11 PM
XR2's Avatar
XR2
Thats right! And most of them work better than WM-Conversions!
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
