Injectors
Injectors
As im putting a new head and cam on soon i was thinking about putting a new set of injectors on as well,
should i get new standard ones or upgrade them, if so what ones?
or should i just get the oned ive got recalibrated, if so where in se london does recalibration?
cheers
cheers
is it for a s2 mate?(going by your name) if it is, then apparently standard mfi injectors are very good for flowing fuel,its the ECU that limits the fueling apparently, so if your still running MFI then stay with standard injectors
AFAIK the metering head / injectors can supply upto 250bhp (on a well setup car), dont know how much more the injectors could flow beyond this, as again it's the metering head that is the limiting factor here.
If you are below this amount of power (most likely) then solong as it is "chipped" then I think you will be ok, im sure someone will correct me if I am wrong.
mk3ste
17-10-2021 10:09 AM
DixieTheKid
11
06-06-2020 11:20 AM
