Diff's & options?
Old May 17, 2006 | 06:54 PM
Kelv's Avatar
Kelv
Almost there!
Default Diff's & options?
is anyone running different diffs atall - wether it be a quaife, gripper or even plated!??
smashed my rear diff to pieces and chewed the splines thru on the pinion aswell, kinda fed up now of braking transmission parts so think its time to go for the stronger options.
in my hunting for a new diff today ive had various options offered to me, the first being a plated rear diff.
anyone had any experience with using a plated rear diff, or what combination of diffs are sugested for both the front and rear.... ie, quaife front with plated rear or best to go for both quaife ATB units?
Old May 24, 2006 | 07:26 PM
Kelv's Avatar
Kelv
Almost there!
Have spoken to Bernie.
managed to get a couple of 3.9 rear diffs to get the car mobile again but rear Quaife ATB with polished 3.9 CWP has been ordered, and front one will be sorted out in a few weeks aswell.
Old May 24, 2006 | 09:54 PM
thedaddie's Avatar
thedaddie
how much did the 3.9 rear quaife diff cost ya?
Old May 26, 2006 | 08:38 PM
Gregs's Avatar
Gregs
is 3.9 std ratio? is it a straight fit?
Old May 27, 2006 | 06:53 AM
thedaddie's Avatar
thedaddie
3.6 is standard, i'm sure its a straight fit
Old May 27, 2006 | 02:45 PM
Kelv's Avatar
Kelv
Almost there!
3.62 ratio is standard, ive steppd mine up to 3.9 for better acceleration on trackdays, and it makes it slightly more lively to drive overall.
it is a straight fit if you get the same 7'' diff.
thedaddie, thru Bernie the Quaife ATB with peened & polished CWP is costing Ł1010 delivered to my door
Old May 28, 2006 | 06:43 PM
thedaddie's Avatar
thedaddie
what gearbox are you running and are you using a 3.9 diff for the front?
Old May 29, 2006 | 03:36 PM
Kelv's Avatar
Kelv
Almost there!
Standard gearbox at the moment with 3.9 step off gears in the transfer box. the 3.9 front diffs are a little bit to weak (or so im told!)
but ive got my eye on a quaife big tooth gearbox which has come up!
Old May 29, 2006 | 11:12 PM
thedaddie's Avatar
thedaddie
isnt it better to go for a fixit kit or is your quaife big tooth going to end up cheaper?
Old May 30, 2006 | 11:04 AM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
anybody use xtrac, afaik that was the stuff ford used,dont see it for sale
very often.heard its well dear!
Old May 30, 2006 | 11:33 AM
JHS's Avatar
JHS
Xtrac is very very expensive!
From what I've heard Fixit is better than Quaife... Spoke to the Fixit guys from Sweden this weekend at the Norwegian Gatebil show. They had the gearbox internals on display, compared to the standard parts.
I know what I'm buying when I'm changing gearbox...
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Sp3no
Sep 27, 2015 07:23 PM
