no ignition on sierra
Old May 15, 2006 | 08:48 AM
xr4x4rs's Avatar
xr4x4rs
Default no ignition on sierra
can anyone help me please
ive just re loomed a sierra estate using a loom out of a running car
ive also put 2wd cosy management on but i dont have igntion
am i rite in thinking that black wires are igntion?
i dont get fuel pump unless i directly feed from 12v and theres no igntion to the ecu or 12v
which is really getting to me now as i want this car gone off my drive lol
i know ive wired the management up rite im 100% sure i have
its just i havnt got igntion anywhere in the main loom so obviously this supplys the ecu aswell
where is the ignition relay on sierras as ive changed a few relays and still the same
any test i can do to see where the fault is ive tried but just having no luck
thanks
Old May 15, 2006 | 08:51 AM
cossiecrew's Avatar
cossiecrew
ryan might be able to help he helped me out with my wiring top bloke
Old May 15, 2006 | 08:56 AM
xr4x4rs's Avatar
xr4x4rs
funny enough im chatting to him on msn now lol, but not about cars lol
Old May 15, 2006 | 09:42 AM
cossiecrew's Avatar
cossiecrew
Old May 15, 2006 | 10:40 AM
xr4x4rs's Avatar
xr4x4rs
still no luck
ive just replaced every relay out of his old fuse box to this one and still no igntion
think hes gona have to send the car away now as i carnt find the fault
Old May 15, 2006 | 10:50 AM
dojj's Avatar
dojj
Resident Wrestling Legend
follow the power trail back to the battery and see if it's broken anywhere
you never know it might be one of the fuseable links gone from the battery or the fusebox itself thats playing up
the wires you want are going to be either black with a blue track of black with a yellow trace
silly i know, but have you actually connected the switch to the key? if you are loking for a feed when you turn the switch but there's nothing turning....................................
Old May 15, 2006 | 11:30 AM
xr4x4rs's Avatar
xr4x4rs
yes ive tested the switch where the key goes
i have 12v all round on it in certain postions
just any black wire in the car loom i dont have nothing
i will check the fuse links and start tracing them back then from the barrel
chowfornow
14
Jan 5, 2019 09:01 PM
muzzman1
Sep 30, 2015 08:59 PM
Daniel Howard
17
Sep 26, 2015 12:39 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
beller
Sep 21, 2015 04:13 AM
