7 x 16s on S1? Help! - photos!!
Bought a set of 7 x 16" Compomotive MO's for the S1, any idea how difficult they wll be to fit? I've seen plenty with Esc Cos wheels which are obv wider so it can be done just curious if anyone else has done it....
Mine also has rear discs and is lowered 60mm all round which will obv make a difference.....
CheeRS
CheeRS
Originally Posted by Dan
I think you'll have problems because of lowering it 60mm mate, it's abit low really for an RST
What offset are the wheels?
If you get them on get some pics up! been wanting white compo's on mine, 16" too!
Never seen it before mate!
Originally Posted by Rick
correct offset 16's will not catch no matter how low the car is. I use 195/45/16 on back, and 215/40/16 on front.
they both look fookin awesome - cheers for all the help - think i'll swp the springs for 30mm one and maybe stiff shocks - the wheels will go on!
Pic of them:
Pic of them:
Dan
Beacuse the front has all the torque going throught them - u need as much grip as possible there - thats where all the weight is. It makes the car feel more neutral too. Rear wheels just get pulled along - no real weight there.
Ok I get that part!
Why thinner tyre's on the back then mate?
Ok I get that part!
Ok I get that part!
Got an old 205/45/16 chucked on, just to get an idea of where I was, its on and fits cool, obv a bit close but the car is lowered on 60mm springs so thats my first port of call, 195/45/16s and raise the ride height a bit but it looks fookin hard
On a less happy note, started taking bodykit off for paint to find there is very little underneath
so looks like resto might take a bit longer
mines on 17's with a 40 mm drop, nut ithink a bit of work happened to do it but their fine.
but want a set of std S1 wheel as well for it and keep the RS7's for the sunshiney days.
They wont be out much then eh
JK12
33
Apr 26, 2021 12:09 PM
STAFFY OWNER
Sep 13, 2015 08:59 PM
