View Poll Results: Do dumpvalves work????
yes
66.67%
no
33.33%
Voters: 21. You may not vote on this poll
Old May 12, 2006 | 11:18 AM
davidnormanuk's Avatar
davidnormanuk
Default Do dumpvalves work????
Thought this might be fun.
Do dumpvalves prolong the life of the turbo on an Escort RST running standard management and standard turbo running about 15psi of boost
Old May 12, 2006 | 11:36 AM
SafeChav's Avatar
SafeChav
Oh god
Watch this space this is going to a FUCKING FUNNY thread
What do you mean by "do they work"
Old May 12, 2006 | 11:51 AM
Oranoco's Avatar
Oranoco
Depends on the application. On a sub 30psi RS Turbo no. On a T4 equipped RS500 or small turbo Escort Cossie yes.
You can't make a sweeping statement across the board as it varies from car to car
Little_Hoss's Avatar
Little_Hoss
this makes me laugh
cant wait till people get really pissed off and start throwing massive technical jargon at each other
Old May 12, 2006 | 12:31 PM
SafeChav's Avatar
SafeChav
Originally Posted by Little_Hoss
this makes me laugh
PMSL laughing
As i'm sure Oranoco will agree, the Pro DV brigade are expected anytime around NOW
Old May 12, 2006 | 12:38 PM
adamS2RST's Avatar
adamS2RST
No.
Old May 12, 2006 | 12:41 PM
Little_Hoss
aye, we'll be b able to hear them coming! poof tish
Old May 12, 2006 | 12:48 PM
SafeChav's Avatar
SafeChav
PMSL poof tish
I have a dump valve at the moment
Old May 12, 2006 | 12:53 PM
Little_Hoss
so do i
looking for a non dv samco
Old May 12, 2006 | 12:54 PM
SafeChav's Avatar
SafeChav
so do i
yea yea thats a bad exscuse if i ever i heard one
Old May 12, 2006 | 12:58 PM
Little_Hoss
at least mines shiny and silver and came of a wrx- the god of all dv's
Old May 12, 2006 | 01:03 PM
adamS2RST's Avatar
adamS2RST
Old May 12, 2006 | 01:06 PM
Little_Hoss
at least i know there shit
Old May 12, 2006 | 01:09 PM
SafeChav's Avatar
SafeChav
WOW!!!!! How much extra Bhp did that give you then
Old May 12, 2006 | 01:16 PM
Little_Hoss
23.9bhp at the flywheel from mickey mouse power house
Old May 12, 2006 | 01:35 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Additionally MFi cars - no. Big power EFi cars - generally yes.
davidnormanuk
Is the poll thingie not working then?
Old May 12, 2006 | 01:45 PM
Little_Hoss
a think that the question that you have asked is to broad
a think the general rule is that they are only needed on high boosting engines 30psi+ like Oranoco said, but then you'll find that even people running this spec dont use them
you deffo wont need 1 for an mfi rst running 15psi
Old May 12, 2006 | 02:04 PM
LEE-RS's Avatar
LEE-RS
Custom
i think performance ford should do a test on dump valves
Old May 12, 2006 | 02:07 PM
davidnormanuk
Would turbo stall (Chatter) harm the turbo when running 15psi.
Thinking about the blades having to stop all of a sudden would it eventually damage the bearing and shaft?
Old May 12, 2006 | 02:11 PM
JimmyBoy's Avatar
JimmyBoy
Why would one work on a RS500 / small EsCos but not others? Dont quite understand that. Could understand the RS500 with its big T4 but it seems a bit contradictory you putting a Small EsCos on there too?
Old May 12, 2006 | 02:40 PM
Mr S1's Avatar
Mr S1
Yeah, but the answer is both 'yes' and 'no' !!!!
Old May 12, 2006 | 02:43 PM
Little_Hoss
am gana stick me neck on the line here from wot i understand you will not get chatter on a mfi set up
am sure some 1 will go into detail about chatter stall wastegates etc very soon
Old May 12, 2006 | 02:48 PM
adamS2RST's Avatar
adamS2RST
Please don't......
Old May 12, 2006 | 02:55 PM
LEE-RS's Avatar
LEE-RS
Custom
Default Re: Do dumpvalves work????
no one can answer your question as they have not been proven to work or not to work
stu as said before that turbo chatter is bad for a turbo and he as even seen it snap the shaft in half and louder the chatter the more damage its doing
Old May 12, 2006 | 02:57 PM
SafeChav's Avatar
SafeChav
FUCKKKKKK better run out and get me one of those badgers
Old May 12, 2006 | 03:12 PM
davidnormanuk
So chatter is bad for the turbo then. I'd assume you still get turbo stall on the MFi setup but just don't hear it due to the system it's running.
So a dump valve may prolong the life of the turbo providing its working correctly.
Do rally cars have a dump valve with running high boost etc to keep the turbo up to speed?
Old May 12, 2006 | 03:22 PM
SafeChav's Avatar
SafeChav
I think rally cars use re-circulating dump valves.
Old May 12, 2006 | 03:35 PM
Oranoco's Avatar
Oranoco
Not at all mate. If you know how a small turbo Escort Cossie works you will know they should have the DV left in place as removing them upsets the air flow sensor as it can't tell which direction the air is being passed over it.
SafeChav's Avatar
SafeChav
Am i right in saying escos's have a small DV from the factory?
Old May 12, 2006 | 03:38 PM
Oranoco's Avatar
Oranoco
They have a plastic recirculating DV from the factory iirc. I'm sure a friendly Escort Cossie owner can fill us in though
Old May 12, 2006 | 03:41 PM
JimmyBoy's Avatar
JimmyBoy
Nope, never knew that.
Old May 12, 2006 | 03:48 PM
SafeChav's Avatar
SafeChav
Yeah that sounds familiar
Old May 12, 2006 | 04:11 PM
HybridBly's Avatar
HybridBly
had a d/v on for years and then visited SCS and was told to throw it away so gave it a try and the difference was amazing holds boost between gear changes and doesnt try and stall. Thats on a stg3 hybrid with modified fins, depends on application i guess
Old May 12, 2006 | 05:34 PM
Ezzy Danny's Avatar
Ezzy Danny
They are only good for dirty skuzzers haha when they ask "oh whats taht whooosing noise"
hahahahaa
Old May 12, 2006 | 06:21 PM
Mr S1's Avatar
Mr S1
So do 3 doors IIRC as a mate turned his round and got the same effect as the wastegate opening...............did it for a giggle on a super mint 3 door to piss his wife off for a few days
Old May 12, 2006 | 07:00 PM
SafeChav's Avatar
SafeChav
Am i being dumb.....how would turning a re-circ DV around change the sound?
Old May 12, 2006 | 07:59 PM
akito-man's Avatar
akito-man
From: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
maybe he turned her around to recirculate her dump valve
sure they work,you accelarate,as you change gear they go,potash,everyone looks,BINGO! they work.
Old May 12, 2006 | 08:58 PM
biglee's Avatar
biglee
Audio specialist
small escos turbo has a re-circulating d/v built on to the side of the turbo, non-removeable........i have this versioin on my S1, with a roller conversion....and i sounds wicked.....it churps....\lol
Old May 12, 2006 | 10:14 PM
neilrev's Avatar
neilrev
,potash,everyone looks,BINGO! they work. [/quote]
fpmsl
