Head gasket on a 3dr
Looking at a 3dr on saturday. Its up for 5.5k but has a blown head gasket? How costly is a replacement? And should i be wary as its had a bottom end rebuild and is running a 4x4 head
ANY ADVISE MUCH APPRECIATED
Either way its gonna cost me
Bugger. Sounds a nice motor, but have to obviously have to be careful in a situation like this. The cars only driven 35k mile, stored 9-10 yr's, but hasnt got the original engine as was high spec and previous owner took it out. As to why im wary?
Gary, make sure it has a 200 block, 2wd block and 4x4 head don't usually mix=high comp=blown gasket
£60 head gasket, bolts £30,skim if required £60 time to strip and rebuild
oil and filter,coolant etc
ONLY IF THE HEAD IS OK TO BE REUSED AND NOT UNDER SIZE
BE WARNED MATE, DON'T WANT YOU STICHED UP!!!!!!!!!!!!!!!!!!
Paul
Paul
Paul
Paul
I think I recall a recent post on here about a sierra for sale with a blown head gasket, might be same person ?
You could do a deal where you got the head off and verified the bill before payment... if he is for real he should be ok with that...
Mc5506
Oct 5, 2015 09:57 PM
