Oil Pump Removal
Old May 10, 2006 | 06:39 PM
aldy's Avatar
aldy
Default Oil Pump Removal
Just been removing everthing ready to change Oil Pump, only to find there is not enough space between the end of the crankshaft and the inner wing to remove it. Please tell me there is a way or is it an engine out job. I'm sure I read somewhere that changing the Oil Pump can be done with the engine still in
Old May 10, 2006 | 06:54 PM
SafeChav's Avatar
SafeChav
Just drop the mount mate and lower the engine enough to slide it off. Bit of hassle but a damn sight easier than taking it out!!!!!!!
Old May 10, 2006 | 07:16 PM
aldy's Avatar
aldy
Cheers, I'll try that tomorrow, really don't think I can be arsed to take the engine out
Old May 10, 2006 | 07:18 PM
SafeChav's Avatar
SafeChav
It will work FUCK taking the engine out MISSIONS
Old May 10, 2006 | 08:01 PM
gambit's Avatar
gambit
Default pump
dont undo the mount there is no need, just:
lower the car on the road wheels then whilst 1 person jurks the engine the oposite way and another pulls on the pump u will get it out. i have done it a couple of times believe me it is the easiest way. you must have the car on the ground or you just cant get the engine to move at all.
Old May 12, 2006 | 04:55 PM
aldy's Avatar
aldy
Ratchet strap from alternator bracket to opposite side anti roll bar, pulled it over enough to remove oil pump
Old May 12, 2006 | 05:02 PM
SafeChav's Avatar
SafeChav
Good thinkin
big_Rad
Sep 15, 2017 09:36 AM
YODI
Aug 30, 2015 01:12 PM
Aug 29, 2015 08:16 PM
Adam-M
Aug 26, 2015 05:53 PM
Dubs44
Aug 21, 2015 02:42 PM
