how do these bolts come off lower suspension joint? *pics*
Old May 9, 2006 | 04:59 PM
dave_y's Avatar
dave_y
Default how do these bolts come off lower suspension joint? *pics*
aparently there is some sort of special tool/key? WTF?
Old May 9, 2006 | 05:06 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
No special tool that I am aware of, certainly didn't need one when I did them on my cossies.
You first need to remove the split pin (bit of wire running through a hole in the thread).
Then, a 17mm socket should get the nut off, I would try and get some WD40 or similar on there first though.
Make sure you get new split pins to put in there when you fit everything back together, they're there for a reason
Oh, you might need a balljoint separator once you have the nut off though, to separate the two "bits". Be careful not to damage the rubber seal on the bottom "thingy".
Sorry about "bits" and "thingy", had a long day and I can't remember what they are called
Old May 9, 2006 | 05:10 PM
SafeChav's Avatar
SafeChav
Tools you need:
17 (maybe 15mm ) ratchet & socket/spanner
Pliers (to remove the split pin)
Ball joint breaker, but for those who don't have one a fucking massive lump hammer usually works
remove the split pin, undo the nut, smash the fuck out of the track rod end until it pops out. Job done
I reckon you should strip your gearbox down next
Old May 9, 2006 | 05:18 PM
dave_y's Avatar
dave_y
strip the gearbox down? piece of piss lol
im in the process of removing the box hence all the questions
thanks for the quick replies fellas, looks like i will be breaking out the large hammer again!
Old May 9, 2006 | 05:22 PM
SafeChav's Avatar
SafeChav
Originally Posted by dave_y
strip the gearbox down? piece of piss blindfolded lol
Easy lets not be too cocky
Old May 9, 2006 | 05:39 PM
addiction's Avatar
addiction
you dont want to be hitting the actual track rod end!! you want to be hitting the part of the hub that the rod end goes through!! it will then spring up and out
Old May 9, 2006 | 06:01 PM
SafeChav's Avatar
SafeChav
My bad.......should of been clearer
Old May 9, 2006 | 06:21 PM
Stoo's Avatar
Stoo
You wont need to remove them to get the box out mate Well, i didnt...
Old May 9, 2006 | 07:01 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
loosen then leave the nut on the thread for a good few turns then give it a slight knock to get it ot of the hub with out damaging the threads
im wondering why your removing the steering components to whip a box out tho
Old May 9, 2006 | 09:47 PM
dave_y's Avatar
dave_y
yup i realised that after i had taken it off.
i was lookin in the wrong place, i was meant to be looking at the balljoint held in place by the Torx bolt.
driveshaft is now out and the box is draining its oil (most of it over the garage floor )
Old May 10, 2006 | 12:18 AM
SafeChav's Avatar
SafeChav
YOU LOVE IT
Scoop the oil up put it through some filter paper.......good as new
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
little bram
Sep 27, 2015 07:45 AM
