Compression Strut Group Buy
Old May 9, 2006 | 10:31 AM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Default Compression Strut Group Buy
As above, any one interested please post
Old May 9, 2006 | 11:31 AM
Azrael's Avatar
Azrael
If it was kind of kit retaining standard ARB I would be.
Old May 9, 2006 | 02:53 PM
rsdene's Avatar
rsdene
yeah mate i would. ones like this tho.
Old May 9, 2006 | 07:55 PM
Speedy G.'s Avatar
Speedy G.
What does this do??
Old May 9, 2006 | 08:55 PM
Kelv's Avatar
Kelv
Almost there!
Same as Azrael, ideally id preffer the kit that keeps the ARB.
and would also depend on how soon the group purchase would aim to be going ahead as would like to get these sooner rather than later!
Old May 9, 2006 | 09:03 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
The kit replaces ARB. Locates front wheels better and allows adjustment of castor angle. Believe you can use with out a seperate Grp A style ARB.
Old May 9, 2006 | 09:04 PM
rinus_2005's Avatar
rinus_2005
Originally Posted by Speedy G.
What does this do??
Well it allows for castor adjustment, but generally standard castor is spot on. However (brake) judder often is caused by the (poly)bushes (the tca and arb) Now with a adjustable tca and compression strut, it is simply not possible due the rose joints. And your wheel allignment is spot on because bushes allow the wheels to be moved in differnt directions, which causes wrong wheel allignment. (less grip, and tyre wear)
Cons can be: Besides the investment it also will transfer rolling sound from the tyres to chassis much more than dampend by the bushes.
Rinus
btw, i'm also interesed but prefer a compresionstrut kit with a (adjustable)arb.
Or can i relocate the original arb just above it's standard location, chop of the tca ends, and clamp it to the compression struts? (rs1600i style)
Old May 9, 2006 | 09:08 PM
Kelv's Avatar
Kelv
Almost there!
Most of the 'cheaper' kits are a direct replacement for the ARB utilising the standard ARB mountings both in the TCA's and on the chassis rail.
for a much better and precise set up the ideal method would be to keep the ARB, Martin @ Reyland is looking at selling the exact kit pretty soon
steve.rst
Mar 15, 2016 08:01 AM
155lee
Oct 27, 2015 04:55 AM
dombanks
Sep 21, 2015 08:38 PM
RS-Rikki
Sep 21, 2015 07:27 AM
beller
Sep 21, 2015 04:13 AM
