fuel presure when the car is switched off should ther be any
Old May 8, 2006 | 07:23 PM
abdr500's Avatar
abdr500
Default fuel presure when the car is switched off should ther be any
fuel presure when the car is switched off should ther be any as mine just go to 0 strate away
Old May 8, 2006 | 10:14 PM
Tim's Avatar
Tim
if its a cossie yes whatever the base pressure was whenu turned it off.
Mine was like yours fecked lol
Old May 9, 2006 | 12:32 AM
SafeChav's Avatar
SafeChav
All EFI cars should retain fuel pressure at turn off.
Probably find your one way valve is fucked (if its got the external bosch pump it screws in the outlet of the pump )
Old May 9, 2006 | 07:47 AM
St3V3_C's Avatar
St3V3_C
I had this, it was the fuel reg.
Old May 9, 2006 | 07:51 AM
If left for long enough it will tend to drop over time.
Often if it drops quickly its an injector sticking partially open due to needing a clean or because its fualty.
Its quite surprising how many injectors end up not sealing properly, whip them off and blow through each one, it should not allow any air to pass when you do so.
How long does it take to go to zero?
Old May 9, 2006 | 07:59 AM
abdr500's Avatar
abdr500
chip-3door
strate away from when i turn the key of it drop to zero the gauge is under the engine bay
Old May 9, 2006 | 02:25 PM
SafeChav's Avatar
SafeChav
Hmmmmmmmm if the system is working ok it should retain a fairly good pressure, i know it drops a bit though
kosienutter
31
Aug 22, 2015 09:55 AM
RSMK4TURBO
Aug 13, 2015 08:06 AM
muffster
Aug 12, 2015 08:14 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
