Smokey Joe
My S2 has started smoking quite a bit when i let off the throttle, it seems fine when its under load just on over run
Any idea's what could be causing this??
If its a turbo problem i have my stg 2 one ready to go on so its not a big deal, if its something to do with the bottom end it could be autotrader time
Sick of spending money on it thats all
Well i've got a stg 2 head and turbo so if it is the bottom end i could always get a low comp jobby and build a new engine
Or just sell it with the head and turbo for someone else with more enthusiasm to do it
Mine did the same.It turned out to be oil in the boost pipes.Put a bailey breather system on it and sorted it.To be honest could be turbo as well, but would try the cheaper option first
Don't ask - I don't know
Sounds like turbo seals Matt. If you've got the stg2 then put it on, won't cost you anything except your time. Process of elimination. Start there.
turbojoe69
Aug 18, 2015 06:41 AM
