ST170 brakes on S1....what is needed for the conversion
Old May 6, 2006 | 01:49 PM
biglee's Avatar
biglee
Audio specialist
Default ST170 brakes on S1....what is needed for the conversion
as above......someone must know what i need...as my focus rs brembos didnt fit..
Old May 6, 2006 | 02:42 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Use 4wd Cosworth calipers and 2wd discs mate - far easier cobnnversion and bolts straight on.
Old May 6, 2006 | 02:47 PM
biglee's Avatar
biglee
Audio specialist
i would love to, however i have brand new st170 calipers and discs, would like to use them as my rs brembos dont.
Old May 6, 2006 | 02:57 PM
Mr S1's Avatar
Mr S1
Fair comment..............to answer your question I don't know. It must be able to be done they might even be a straight bolt on job. I'd ask in GD mate, get more views there.
Old May 6, 2006 | 11:26 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Easy to do.
Will need to drill the hole in the hub for bigger bolt. Then tap a new thread if i memba right.
Use spacers to get the right offset.
Very easy to do.
Old May 6, 2006 | 11:28 PM
biglee's Avatar
biglee
Audio specialist
nice one ...cheers
Old May 7, 2006 | 11:13 AM
Johnny Knoxville's Avatar
Johnny Knoxville
Don't drill and retap.. Drill and fit stud and nuts
I think they need to be spaced out by 5mm?
Old May 7, 2006 | 11:31 AM
mercury grey minter's Avatar
mercury grey minter
Default Re: ST170 brakes on S1....what is needed for the conversion
Did you get the conversion brackets or asume that they wouldn,t fit.ZOO MOTORSPORT are now open and selling the brembo conversion brackets for Ł100. TWINS of here has the conversion,so they must fit.
Old May 7, 2006 | 05:39 PM
CliffRS4's Avatar
CliffRS4
I think I remember the spacers being about 12 - 14mm long.
Hope that helps
Old May 7, 2006 | 08:46 PM
rswoza's Avatar
rswoza
Hope that helps
ive got 4 stainless steel spacers mate if you need them send a pm they are 14mm btw.
ive got the st170 set up on my car
Old May 7, 2006 | 09:58 PM
biglee's Avatar
biglee
Audio specialist
they would fit on my car no problem, they just wouldnt go under my rs7's calliper fouled the wheel ...oh dear....hence the ST jobbies, as i want to keep my wheels...
Old May 8, 2006 | 05:30 AM
mercury grey minter
What size are your rims and did you actually buy the brackets or did someone tell you they wouldn,t fit behind your rims?also where did you get the brackets from in the end.
Old May 8, 2006 | 11:44 PM
biglee's Avatar
biglee
Audio specialist
got some made for the job mate, as i say it all fitted together really snug and worked a treat, looked so bloody big on my motor....i went to fit the wheels back on and ....you know the rest...its fouling by about 3mm i guess so not much at all but enuf.. if i used mo's then i would have no problem....however i want the rs7's
Old May 9, 2006 | 08:13 PM
mercury grey minter
SHIT!!!!! I hope mine fit,,I thought you would of used 4mm spacers to make them fit.
Old May 10, 2006 | 12:26 AM
biglee's Avatar
biglee
Audio specialist
they dont fit in the diamiter of the inside of the wheel, the off-set is good
Old May 10, 2006 | 03:57 AM
Benni's Avatar
Benni
Ban[B][/B]ned
Unlucky mate.
Old May 10, 2006 | 08:20 PM
mercury grey minter
Got ya,will have to try mine the weekend.Have you tried the 4wd cossie front caliper upgrade.It,s a piece of piss to do and fits spot on.
Old May 10, 2006 | 08:42 PM
biglee's Avatar
biglee
Audio specialist
last resort, wanted to be a bit different ...lol
Old May 10, 2006 | 08:54 PM
mercury grey minter
Where did you get ya brackets from and how much were they????
Old May 10, 2006 | 09:01 PM
biglee's Avatar
biglee
Audio specialist
had a local m/sport place make them for me and cost Ł120
Old May 10, 2006 | 09:07 PM
mercury grey minter
Whack them and the calipers on E-BAY .I bet you get your money back ....P.S your rims are 17 inch aren,t they.??
Old May 21, 2006 | 03:54 PM
rscabrio's Avatar
rscabrio
Does anyone know if i can i fit the focus brembos with 300mm st170 discs onto my escort if i get some caliper brackets made up
Old May 21, 2006 | 04:09 PM
notSteveS2's Avatar
notSteveS2
yes 17s!
Old May 21, 2006 | 10:25 PM
biglee's Avatar
biglee
Audio specialist
now i like that idea, mine will fit then lol
c20tbo
Aug 17, 2015 10:19 PM
track.focus'd
Aug 12, 2015 05:53 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
col93saphcos
Aug 7, 2015 03:21 PM
Bosch
Aug 4, 2015 05:14 PM
