oil pressure post
Old May 5, 2006 | 03:23 PM
rob w's Avatar
rob w
Default oil pressure post
can't find the post asking people their oil pressure.
help reqd.
Old May 5, 2006 | 04:25 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
What do you need to know ?
Think its not less than 28psi hot idle
Steve.
Old May 5, 2006 | 04:40 PM
JimmyBoy's Avatar
JimmyBoy
Haynes manual states minimum oil pressure should be 1.0 BAR (14.5PSi) at 750RPM, 2.8 BAR (40.6PSi) at 2000RPM and the oil pressure warning light activates at 0.3 - 0.5 BAR (4.3 - 7.2PSi).
Old May 5, 2006 | 05:00 PM
rapidcossie's Avatar
rapidcossie
was told the warning light comes on at 15psi??
Old May 5, 2006 | 07:31 PM
Mine is not much over a bar on idle, but it idles under 1000
Old May 5, 2006 | 07:32 PM
_DAN_'s Avatar
_DAN_
Yoon
What about shoving a shim in the spring to riase it?
Old May 5, 2006 | 07:45 PM
RS500/364's Avatar
RS500/364
well when hot mine is 40.6PSi
Cold around 60 on start up
Old May 5, 2006 | 08:21 PM
edd's Avatar
edd
my kitcar is 85 cold and 65/70 hot
Old May 6, 2006 | 09:13 AM
Neil S's Avatar
Neil S
Surely it depends entirely on the car!!!!
Neil.
Old Jun 1, 2006 | 05:22 PM
pee vee's Avatar
pee vee
How much does the type of oil you use affect this??
im seeing 80psi at cold idle and drops to 40 psi at 60 degrees,
but have not had the car warmer than that yet
worried its gonna drop too low lol
this is using 10-40 mineral oil at the mo
Adam-M
Aug 26, 2015 05:53 PM
mrmann
Aug 20, 2015 11:24 PM
