Whats the best thing to use for cleaning out a header tank
Old May 4, 2006 | 09:52 PM
simonc's Avatar
simonc
Default Whats the best thing to use for cleaning out a header tank
Whats the best thing for cleaning out an alloy header tank, its coated in brown rusty water inside, also when i removed the top & bottom hoses noticed they are a bit crudded with brown rusty sludge, was going to run a coolant flush through the engine, is that the best thing to clean out the system ? Its not really that bad but i'm a bit fussy.
Any ideas what to use ?
Simon.
Old May 4, 2006 | 10:07 PM
The Sludge's Avatar
The Sludge
garibaldi
vinegar dude works really well. but dont use through the system
Old May 4, 2006 | 10:09 PM
SPADGE's Avatar
SPADGE
Can't argue with a man called 'The Sludge' on this topic
The Sludge's Avatar
The Sludge
garibaldi
Old May 4, 2006 | 10:15 PM
simonc's Avatar
simonc
Thanks for the advise You obviously know your sludge
Used the last of the vinegar on the chips last night Will buy some tommorrow
Thanks Simon.
Old May 5, 2006 | 07:00 AM
richj's Avatar
richj
I think I read somewhere that baking soda works too.
Old May 5, 2006 | 07:25 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
If you can get to Halfords they do a rad cleaner. You pour this in to the top of the rad and fill up as normal with water. Obviosuly this circulates through the entire cooling system so will clean your header tank and any shit you have in the water pipes. they do 2 types a noraml and heavy duty version. Works very well.
Old May 5, 2006 | 07:29 AM
Redkop's Avatar
Redkop
Thanks Simon.
It's white vinegar you need to buy.
Old May 5, 2006 | 09:08 AM
Joris_FRST's Avatar
Joris_FRST
You might try pickles or mayonaise
Old May 5, 2006 | 11:44 AM
gingeRS's Avatar
gingeRS
take the header tank off, plug and fill with caustic soda.
give it a shake, then leave and this will clean it a treat.
Old May 6, 2006 | 08:33 PM
simonc's Avatar
simonc
Removed the header tank & filled with vinegar, its been in there a couple of hours but hasn't really done much to shift the brown crap in the bottom, do i need to leave it overnight ? Where would i buy caustic soda from ?
Simon.
Old May 6, 2006 | 08:35 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
My engine is dead Simon
Steve.
Old May 6, 2006 | 08:41 PM
rapidcossie's Avatar
rapidcossie
the rust is prob from the small metal pipe that bypass's the rad..
get yourself a new one or the rusty water will just come back after you clean it
Old May 6, 2006 | 08:46 PM
simonc's Avatar
simonc
Do you mean the metal pipe at the bottom of the rad that usually rusts real bad ? If so i changed it a couple of years ago for a bling polished item.
Simon.
Old May 6, 2006 | 08:51 PM
89xr2's Avatar
89xr2
Brap!
Stick it in the dishwasher.
Old May 6, 2006 | 08:52 PM
Damo V's Avatar
Damo V
Water
Old May 6, 2006 | 08:53 PM
rapidcossie
Simon.
yeah mate...your sorted then
JK12
33
Apr 26, 2021 12:09 PM
Rsmat
63
Sep 25, 2015 12:11 PM
mint_s2
Sep 2, 2015 08:58 AM
AndrewStrang
Sep 1, 2015 11:16 AM
