Am i losing power with a whining turbo.
Old May 3, 2006 | 08:37 PM
petermintrst's Avatar
petermintrst
Default Am i losing power with a whining turbo.
My turbo is whining...the police siren noise. and whistles louder than it used to. so from what i've read the main bearing is worn which means it hasnt got long left.
but, will i be losing power due to this? when i first got the car, it sounded fine and was pulling well. now the turbo is whining, it still seems to go as quick, but is it? surely i must be losing power. or is every case different?
Old May 3, 2006 | 09:28 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Well does it still hold boost as it did?
Old May 3, 2006 | 10:08 PM
biglee's Avatar
biglee
Audio specialist
the noise you are hearing is the impeller scraping the compressor housing at silly speeds, it will still work, for a while...
however, you will find if you continue to use it like this then it wont be long before it really goes tits up.... imo you should get it re-cond asap...
in extreme cases ive seen the impeller worn away quite alot....thus means small shards of metal going into your engine,,,,not good at all
lee.....
Old May 4, 2006 | 12:06 AM
SafeChav's Avatar
SafeChav
To add to that aswell if you use it too much then the shaft may also be scored beyond repair....
Catch it in the early stages, as with most things, and generally its for the better cost wise
Old May 4, 2006 | 07:11 AM
petermintrst
ahhhh right, now comes the question - where is a good place to either get it reconed or swapped for a new one? fitted etc.
pref in the northwest area
Old May 4, 2006 | 10:15 AM
antony215's Avatar
antony215
Escort Rs Turbo
Try these dont know if they do an exchange http://www.turboactive.com/sess/utn;...rbo.shopscript
Old May 4, 2006 | 03:35 PM
Rick's Avatar
Rick
it will be past rebuild stage now, comp wheel will be screwed, and out of balance.
Old May 4, 2006 | 07:59 PM
petermintrst
i've got a new turbo sorted now, should be good when its fitted.
Old May 5, 2006 | 03:51 PM
CliffRS4's Avatar
CliffRS4
Just a good excuse to get a stage 3 T3 on there
Old May 5, 2006 | 07:23 PM
petermintrst
nope, standard exchange. im happy with that.
just think when i come to sell it and its still standard
i'd love the extra power, but once i feel the extra power i'll know i want more more more. besides 200bhp is bugger all use on the bala road in wales. i couldnt go any faster on there than i already do. i aint got the skill to go quicker than i do.
Old May 5, 2006 | 07:28 PM
SafeChav's Avatar
SafeChav
Sounds sensible to me and has the cars best interests as the priority
Old May 5, 2006 | 08:12 PM
petermintrst
yeah, and my bank accounts interest. why spend money to make it faster and whilst doing that immediately lose money on it.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
SMILER258
Sep 28, 2015 09:04 AM
