Show your cossie breather set ups please
Old May 3, 2006 | 11:39 AM
KSA-Cossie's Avatar
KSA-Cossie
Default Show your cossie breather set ups please
Thankyou.
Old May 3, 2006 | 11:43 AM
Csm's Avatar
Csm
Soz about piccy quality kev
that is the tank in the corner behind the battery ,i really need a better camera
Old May 3, 2006 | 11:52 AM
RobS's Avatar
RobS
My Bailey
Old May 3, 2006 | 11:55 AM
le-claw's Avatar
le-claw
Old picture
Old May 3, 2006 | 11:59 AM
KSA-Cossie's Avatar
KSA-Cossie
Is that a bailey one mr mills ? Can't quite make it out in your stunning picture !!!
Old May 3, 2006 | 12:00 PM
KSA-Cossie's Avatar
KSA-Cossie
Originally Posted by RobS
My Bailey
Where do the bottom pipes go to rob ? Stunning bay there m8.
Old May 3, 2006 | 12:02 PM
rstoughy's Avatar
rstoughy
GGR Setup
Old May 3, 2006 | 12:24 PM
Csm's Avatar
Csm
Tbh ,i think its all spec r stuff ,i have been lookin through previous reciepts for a look ,but there is mountains of paperwork and a few less trees
Old May 3, 2006 | 12:27 PM
KSA-Cossie's Avatar
KSA-Cossie
Old May 3, 2006 | 12:40 PM
cossiestu's Avatar
cossiestu
Old and new;
Old May 3, 2006 | 12:43 PM
KSA-Cossie's Avatar
KSA-Cossie
Why did you change stu ?
Old May 3, 2006 | 01:06 PM
cossiestu's Avatar
cossiestu
I thought the mirror image jobby looked a lot neater, although not much clearence for the hoses by the strut brace...
Got it for a good price too. Must e-bay the old one, one of these days!!
Old May 3, 2006 | 01:14 PM
KSA-Cossie's Avatar
KSA-Cossie
I just bought one too.
Old May 3, 2006 | 01:27 PM
Sticky.'s Avatar
Sticky.
Old May 3, 2006 | 05:45 PM
Paul.'s Avatar
Paul.
Roosemotorsport set up.
Regards Paul.
Old May 3, 2006 | 05:56 PM
Stu @ M Developments's Avatar
PassionFords Creator
Its amazing how many non functional breathers are out there!!
Do some research before spending your money if thats your intention Kev...
R4N SS's Avatar
R4N SS
Regards Paul.
now that looks fookin awesome
Old May 3, 2006 | 07:05 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
Regards Paul.
oooooo that hurts my eye`s
Old May 3, 2006 | 07:19 PM
mcrmatt1983's Avatar
mcrmatt1983
What does the breather do?
Old May 3, 2006 | 07:31 PM
Basky's Avatar
Basky
Old May 3, 2006 | 07:36 PM
KSA-Cossie's Avatar
KSA-Cossie
Have bought a bailey one is that no good ?
Old May 3, 2006 | 07:45 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
pro alloys effort
Old May 3, 2006 | 07:50 PM
mk2rstaff's Avatar
mk2rstaff
would show you mine but not got a fittin kit
Old May 3, 2006 | 08:05 PM
KSA-Cossie's Avatar
KSA-Cossie
Me neither .
Old May 3, 2006 | 08:07 PM
mk2rstaff's Avatar
mk2rstaff
i got a weird bottle its got thin pipes out one at the top as normal then a thin one out the bottom with the gig main breather hole out the bottom centre
Old May 4, 2006 | 07:59 AM
Neil S's Avatar
Neil S
No, they're fine, but you need to return to the sump below the level of the oil, breathe from both sides of the block, and ensure your vent pipe is large enough
The standard install is pish, but they will do you all the hoses and fittings you need if you call them - they were very helpful with me, sorted me out exactly what I needed
I run one with a non-standard install, see Stu's comments on this thread
Neil.
Old May 4, 2006 | 10:50 AM
Damo V's Avatar
Damo V
GGR/Tarcal 4 port breather (both sides of block) and catch tank
And return to sump BELOW oil level
Old May 4, 2006 | 11:34 AM
rapidcossie's Avatar
rapidcossie
how much oil is actaully returned to the sump if the breather is working correctly on a healthy engine??
as im thinking of changing my standard bailey set up to breath both sides of block but would be a while before i could get the return back under oil level drilled into sump...
Old May 4, 2006 | 11:39 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
do not return below oil level on a yb turbo
Old May 4, 2006 | 11:41 AM
Afternoon sexy. Glad to see you still stock the old Can O Worms at Turbosystems.
Old May 4, 2006 | 11:42 AM
bud-weis's Avatar
bud-weis
Football Cwazy
fight fight fight
Old May 4, 2006 | 11:46 AM
Turbosystems
Super Moderator
the oil return needs to be large bore and that includes the fittings .
The theories of a closed return and the arguements that can be put forward are of great merrit but the world was thought to be flat for thousands of years too.
Any one feeling peckish worms on toast any body lol
Old May 4, 2006 | 11:55 AM
le-claw's Avatar
le-claw
I dont have any issues with mine returning below the oil level.....
Old May 4, 2006 | 12:03 PM
Turbosystems
Super Moderator
le- can opener
Old May 4, 2006 | 12:15 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Very interesting reading - we need a tech article on breather systems if one hasn't been done already
Old May 4, 2006 | 12:16 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Tony - if we can't return below the oil level on a YBT engine, then why does the standard kidney box on the side of the block have a pipe to take returned oil below the oil level via the standard breather system?
Old May 4, 2006 | 12:21 PM
Turbosystems
Super Moderator
good point and can be used as a lesson for everyone they piss oil out into the air box of a standard car so clearly it doesn't work lol.And the world is round or is it flat
Old May 4, 2006 | 02:01 PM
Dave Henshall's Avatar
Dave Henshall
ROFL
Old May 4, 2006 | 03:34 PM
rapidcossie
come on guys can we have a proper technical feature made up?
pros and cons of both systems?
Old May 4, 2006 | 04:12 PM
foreigneRS's Avatar
foreigneRS
Testing the future
as far as i know, the function of a breather is to relieve the build up of gas in the crankcase area (which may be linked to the cam cover or wherever) caused by piston ring blow by.
an effective breather can be something as simple as a hole in the side of the crankcase, but that would piss oil everywhere so you have a separator to seperate the oil from the gas. it is that separation process that needs a little care to be most effective.
most engines have a basic system (like the 'kidney box' on a pinto/yb block) that are supposed to perform that function by making the mixture go through a twisty route or a gauze or whatever to try and separate the oil that then runs back down into the crankcase under gravity. as tony says, the std yb one is shit, as it pisses oil into the airbox, whereas 'clean' air should be returned there to be consumed by the engine. it's handy for keeping your k&n panel filter well oiled though if you fit the breather pipe before it
what i don't understand is why a lot of these systems that we see have 2 tanks one well designed one should be enough, surely? you would have the crankcase breather (and again, 1 should be enough if it's big enough) going to a vessel that has an outlet at the top for clean air to go back to the inlet and an outlet at the bottom for the oil to drain back to the sump. I can understand 2 tanks if one is a catch tank for the oil rather than having it returning to the sump.
and what's with the miniature filters? surely air is not sucked in through there, only exiting, so why the need for a filter.
maybe my understanding is completely wrong. could be a topic for one of stu's essays, or one of his articles now that he's a pro journo and has forgotten about us techies on here that love his free info
