newman cam
Old May 1, 2006 | 05:44 PM
Hrsturbo's Avatar
Hrsturbo
Default newman cam
with the cam kit with solid lifters etc will I be able to remove the rev limiter and rev to 7k or do I need to do any other mods?
also how many miles will the newman cam last for as I know kent and piper don't last long!
Old May 1, 2006 | 05:51 PM
stuart collins's Avatar
stuart collins
ive just had the lastest newman cam fitted mine revs to 7.3k will do more if i want
Old May 1, 2006 | 05:54 PM
Hrsturbo's Avatar
Hrsturbo
was it easy to fit?
is there much lag?
how much is the latest going for and which profile have you gone for?
Old May 1, 2006 | 06:00 PM
stuart collins
i didnt fit it , ive got to much lag at the mo so change exh housing and goin tubular manifoild im gettin full boost at 4.1k ish and it stops makin power round 7.1kish
Old May 1, 2006 | 08:00 PM
Rick's Avatar
Rick
stuart collins
what hosuing have u got?
Old May 1, 2006 | 08:16 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Newman only make one cam for an RS Turbo, and the sticker on the box says ZVH.........
Old May 1, 2006 | 08:18 PM
JamboRS's Avatar
JamboRS
focus rs 1672
newman only list one cam for the rst,but they do custom ones to the customers spec
Old May 1, 2006 | 09:47 PM
Taylor's Avatar
Taylor
Cool was wondering this myself!
Old May 2, 2006 | 12:15 AM
T28 RST's Avatar
T28 RST
Ok then
Ive got one in my CVH
Old May 2, 2006 | 08:11 AM
Tony Turbo's Avatar
Tony Turbo
So have I..... And your point is???
Old May 2, 2006 | 10:56 AM
stuart collins
Originally Posted by Rick
stuart collins
.63 goin down to a .48 with a tubular manifold
Old May 3, 2006 | 09:29 AM
Hrsturbo's Avatar
Hrsturbo
When ordering, what extras do I need?
Choice of:
8 x double valve springs
8 x hydraulic cam followers
1 x clamping tool for adjusting mechanical cam followers
8 x billet mechanical cam followers easy adjustment no shims
8 x chrome moly valve caps for double valve spings
vernier pulley
am i right in thinking you only need one of the choices 2 or 4 and need the rest?
Old May 4, 2006 | 03:54 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Choice of:
vernier pulley
Hold on, you referred to Solid lifters, then Hydraulics??
You want the CVH cam, a set of 8 Solid followers, double springs with their caps and the adjustment tool.
Are you fitting this? The adjustment really isn't very easy, it certainly wouldn't get a '1 spanner' rating in Haynes anyway.
BTW, Tony, you are wrong, as much as I hate to say it!! LOL. They do 2 ERST cams, one for CVH and one for ZVH and IMO the whole custom thing is a white elephant. They can do custom spec, but I think you will find that they rarely do.
Mine is though and so is Tony's!!
Old May 5, 2006 | 08:59 AM
Hrsturbo's Avatar
Hrsturbo
Yeah I gonna give it a go fitting it
I ordered it all yesterday but theres a 2 week wait as they ran out of solid followers
First time doing any real engine work, only done clutches etc
Looking forward to it! I think the timing is gonna be the worst bit!
Getting my rocker cover powder coated while its off, putting on new belt, oil seals and rotor arm and cap.
Any tips? Any thing else I should do while its apart?
Old May 5, 2006 | 04:52 PM
JamboRS's Avatar
JamboRS
focus rs 1672
and mine,davie k's,andy r's and davie ch's
sure andy r has had 2 different specced ones
Old May 5, 2006 | 07:17 PM
Andy_R's Avatar
Andy_R
Jamie hope my last "agressive 1" is being put to good use it was/is a "one off"
In answer to the original question .Yes you can raise your rev limit! however there will become a point before 7000rpm where other factors limit your (peak) power. In effect reving higher (which in time causes other related issues) for the sake of it!
Old May 5, 2006 | 07:52 PM
Rick's Avatar
Rick
I'm guessing ZVH has more duration? The head is identical, so maybe they are using the extra capacity as a lag reducer. I hate it when comapnies specify recommentations. Tell me the timing figures and i'll tell u if i want it lol.
Old May 6, 2006 | 03:08 PM
Tony Turbo's Avatar
Tony Turbo
My bad.... It's been a while since I have spoken to Newman I guess lol.
Thanks for correcting me.......
Old May 6, 2006 | 08:12 PM
rstdave's Avatar
rstdave
As said above, when i ordered mine they didn't seem keen on a custom grind....sayin that the one they make was what they considered best! Also as c+b said, adjustin the lifters is a bloody time consumin affair, i can see why a garage would charge u alot of dollar to fit one!
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
