Boost Question
Old Apr 29, 2006 | 05:39 PM
Damienholmes's Avatar
Damienholmes
Default Boost Question
I got a 2 stage boost controller in my car linking to a brand new amal valve. Now before my car went in for some work it was running 13 PSI on low boost and 26 PSI on high boost.
Since then ive had some work done on the car, the following: New Radtec twinfan intercooler, Pace Alloy Rad, Series one Chipped turbo systems ECU, New metering unit and a new amal valve.
Now the cars all back together the low boost setting runs 10 PSI and when i switch it to high it only reaches 15 PSI, How can this be adjusted ?
Old Apr 29, 2006 | 06:54 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
You need to take care here. You might find that you have an air-leak somewhere. If you adjust the boost now to correct the shortfall, then in the future you find a leak and fix it, you will be producing ALOT more boost than the engine can handle.
Best bet is to have a good look over the work that has been done and check for leaks.
Old Apr 29, 2006 | 08:23 PM
AJC's Avatar
AJC
sod that idea, just turn the actuator
no, only kiddin, as christian said
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
