Under bonnet stickers 1993 car-what should there be?
Following on from Paul's thread showing his new under bonnet stickers.
My car has no air con so what stickers should it have under the bonnet
Mine has the dipped light one on the slam panel
one on the brake fluid tank
should there be one on
A. The battery cover -and what should it be?
B. The header tank - as above
C. anywhere else?
they are only meant to be fitted to proper ford plastic covers, not cheap copy metal types
You cheeky begger, mine isn't metal it was bought just recently from Ford and it's made out of cheapo plastic just like yours
I also have exactly the same one as yours in mallard too, as a spare
