Bullet Proof Under Seal
Old Sep 30, 2003 | 09:15 AM
Ferd's Avatar
Ferd
Default Bullet Proof Under Seal
Hi
Had the underside of my car sand blasted not so long ago and the man said the stuff under the wings is Bullet proof. (He’s not far out)
Any one out there know of any think that will take this off other than a blow torch and wire wheel brush on a drill
Old Sep 30, 2003 | 09:09 PM
cossiemen's Avatar
cossiemen
Whassup
nope
Old Dec 12, 2003 | 05:09 PM
i got mine off with paint stripper but not nitromors it was from a panel supplier and was just called heavy duty paint stripper its for 2k paint systems but you got 2 b careful as its extremely strong
Old Dec 12, 2003 | 05:42 PM
The way i get it off is to warm it up with a blow torch or hot air gun, once it starts to smoke use a scraper to scrape it off, after most of it is off use a wire brush to tidy it up.
Old Dec 13, 2003 | 05:53 PM
Just perseverence really. I did this job only yesterday and it needs a good wire brush in an electric drill working it slowly.
Old Dec 28, 2003 | 12:46 PM
R4N SS's Avatar
R4N SS
cant u not leave the stuff on and put a new layer off the top.
Old Dec 28, 2003 | 01:22 PM
DazC's Avatar
DazC
Heat the opposite side of the panel (the bit that doesn't have the sealer on) up with a heat gun and you will see the sealer blister and start to peel off itself. Use a scraper and it will just come straight off.
Old Dec 29, 2003 | 11:17 PM
ESCYSCOTT's Avatar
ESCYSCOTT
I would leave it on mate and just scrub it clean and paint over it because if you take it off you are taking away the floors protection and then you can hear every stone clank onto your floor when driving
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
muzzman1
Sep 30, 2015 08:59 PM
