Headgasket for 2.0 ZVH Turbo
Hello,
I've got a problem with my ZVH engine.
It hasn't even properly run in yet but already i've got a problem.
Got a lot of white smoke coming from the exhaust.
It had a cooling problem some time ago with the result of high pressure in the cooling circuit.
I think the headgasket has gone ( felpro 1.9 gasket)
This has a weakspot in it as seen on this site
http://www.quantums.info/zvh.htm
As i'll be running some boost i don't want this.
I've heard a focus gasket ( steel ) wil also fit.
Who knows if this is true, wich one will fit and where can i get this or can another gasket be fitted?
Thanks a lot,
Gregor
Thanks a lot,
Gregor
the focus one will fit but you will have to get your head welded for it ian howell does this at area 6
http://www.area-six.co.uk/home.htm
@ LEE-RS .. I'm From Holland so... but didn't know welding would be needed..
@ savechaf .. I don't like to modd like this but if there's no other option....
Thanx for the tips.
Thanx for the tips.
Just pulled of the head...
Can't see anything wrong with the gasket .... ( don't have the problem mentioned on the site either) .
But now i'm wondering where all the smoke is coming from...
Oilcooler or the Turbo cooling perhaps?
Who's got any ideas,,,
Thanx again
Thanx again
Hmzz is this possible.... i haven't even driven the car yet...
I revved it a bit but nothing much....
The cilinders loke fine to me..
sure hope it's not a cracked head/block....
No cooling fluid was in the oil .... well .. have a look again tomorrow
Thanx anyway
Thanx anyway
Will have a look at it....
Its got new valve seals in the head..
The turbo is a stage 3 T3 of about 3 years old but only one summer used.
Hope to sort it soon thought.. thanx
The zetec blok is unlikely to be broken i reccon, but how can i check if there any cracks or something in there.
And how can i check if the head hasn't been busted?? everything looks fine to me and the seals from the turbo won't leak within a few minutes from nothing to the whole garage misty within 20 seconds
cheers
cheers
JK12
33
Apr 26, 2021 12:09 PM
big_Rad
Sep 15, 2017 09:36 AM
