my fuel pump relay as stoped working theres no prime when you first switch the ignition on oh when cranking it over it will only work if you bridge the connections from the live positive to the fuel pump live i have tried a new working relay still the same
bridging from the ignition live feed also works bridged from battery live feed so i know they are working ok i was thinking could it be the Coil negative feed ?
So are you bridging from the Black on the fuel pump relay plug? It WONT be the coil negative, i can see your thinking though, but the prime is activated from the ignition going live, and the relay will also turn on from LT signals, the fact you are getting neither means another fault.
I presume the car will run if you bridge the relay?
My guess, is you have popped a fuse for the permenant 12v supply to the relay.
Check for:
Permenant 12v on the Red (where my money is on the fault being)
Switched 12v on the black
Ground/Earth on the Brown
